Need help about router and switch
fakharict
i'm going to design a network with 400 nodes/host need data and voice services in an indoor environment .So kindly guide me which Cisco products (core Router, L3 switch,firewall,WLC, Access Switch and wireless Access point)will be suitable for my scenario and i m looking for a cost effective solution .
regards
Fakhar Mirza
Zach S
Fakhar,
I can't speak to all of your questions here, but Cisco has a convenient solution for Voice networks of under 1000 users. This is the Business Edition 6000, often shortened to BE6K. I've seen a lot of people praise it on the VoIP forum as an easy solution for small business. It's not a good idea if you're likely to grow beyond 1000 users, but if you are staying fairly static in size then it's not a bad option.
Here's a link to info about it: http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/qa_c67-703226.html
Hi fakharict, I would need to know the features you are looking into and some other details regarding your network so we wont "overkill" your network. please send me an email at fguasque@cisco.com so I can help you come up with the most efficient and cost effective solution.
Ferdinand
