Need Help Deciphering Cisco 1841 Part Numbers
jaydien1358
Level 3
Level 3
We have a customer who is internested in the 1841 series router.
We need to get some explanation on the different part numbers for this router. In particular:
Security Bundles
CISCO1841-SEC/K9
1841 Security Bundle,Adv.Security,64FL/256DR
CISCO1841-HSEC/K9
1841 Bundle w/AIM-VPN/SSL-1,Adv. IP Svcs,10 SSL lic,64F/256D
CISCO1841-T1SEC/K9
1841 Security Bundle w/ WIC-1DSU-T1-V2, Adv.Sec.,64FL,256DR
What do all the acronyms in the part numbers mean?
What does K9 mean?
Does the part number with the T1 in it include a T1 wic? If so do the other part numbers just include an ethernet WIC for cable/dsl broadband connections?
-Thanks
Brian
Look in the Quick Reference guide (http://www.cisco.com/en/US/prod/qrg/index.html) - according to it, the HSEC bundle adds the AIM-VPN module.
That module supports hardware-based encryption; thus the increase from 100 to 800 VPN tunnels supported.
Hope this helps.
Giuseppe Larosa
Hello Brian,
a 1841 should have one or two built-in lan interfaces.
w/ = with
K9 = with 3DES encryption
WIC-1DSU-T1-V2 a submodule with T1
AIM-VPN/SSL-1: hardware encryption module
Hope to help
Giuseppe
What is the difference brtween SEC & HSEC? I noticed that there are two part numbers like that.
-Brian
Hope this helps.
Thank you for the response.
