Need help elimintating an error message that is filling up the log buffer
tvancamp6
We have a 3750 in our environment that is receiving the following error:
usoh-nroyalton6945-sw1#show log
Syslog logging: enabled (141 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 4977 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 1747373 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 245691 message lines logged
        Logging to 10.1.124.22  (udp port 514, audit disabled,
              link up),
              245591 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 163.243.54.184  (udp port 514, audit disabled,
              link up),
              filtering disabled
        Logging Source-Interface:       VRF Name:
        Vlan999
Log Buffer (4096 bytes):
154352674: Sep 23 17:21:48:  Failed to send hrpc non blocking message
-Traceback= 4FDAD4z 20665E4z 20666D0z 3D114Cz 3BEB38z 3BFF28z 3DFC38z 3FFE90z F6FC0z FC468z FCE70z FFD1Cz EFE64z 26BF904z 26BA058z
We are planning to upgrade this device, but since it is a critical device the upgrade will have to be scheduled for downtime. In the meantime, I'd like to filter this message from the log buffer and was looking for some insight on how to do so. I tried using a log discriminator, but did not know the proper syntax to remove the hrpc error.
Martin Moran
Level 3
Level 3
Hi @,
See the following references:
https://supportforums.cisco.com/discussion/11455186/cat-3750-failed-send-hrpc-non-blocking-message
https://damn.technology/cisco-failed-send-hrpc-non-blocking-message
Let me know.
Rgrds,
Martin, IT Specialist
