Need Help For Configuring EIGRP in Cisco Packet Tracer
Ali Imam
I am using Cisco Packet Tracer 6.2 Student Version. I am configuring EIGRP between two Routers. After the configuring and when I am ping from PC0 to PC1, I am receiving a reply "Destination Host Unreachable". Why?
I am attaching the original Cisco Packet Tracer Saved File. The File Is in .zip Format Kindly extract it and check that and Resolve my query.
Thank You,
Ali Imam
bakers1991
You need to put the connection between the two routers on the same subnet before EIGRP will form a neighbor relationship. Review your basic EIGRP configuration skills and the items that should match, such as subnet ID and subnet mask, among other items. Your EIGRP config is invalid, therefore the routes will also be non-existent for the PCs to use to reach one another. I have fixed it for you and attached...
