Need Help Importing Configuration File
lamav
Level 8
Level 8
Folks:
I am in a situation in which I need to automate the configuration of some Cisco 1242 wireless AP devices.
I have a configuration that I generated and it is in a .txt format. You know, just typed the comands on Notepad.
Now, I need to upload them to a tftp server and then use the 'copy tftp start' utility to import the configuration to the AP.
How do I change the file format from .txt to the format used by Cisco's IOS? In short, how do I take my config file that I created with a normal text editor and use it to configure the AP in an automated fashion, using the command utility?
Also, what is the file extension used by Cisco for the startup configuration? For the IOS, for example, it is a .bin file. And for startup?
Im sorry if the question seems dumb. I have never had to import config files that werent already sitting on a Unix server and already in the correct format.
Hi Victor,
use the WordPad application to save your config instead of Notepad. IOS do read this format .
Hope this helps
Shaheen
Yes, youre right. WordPad worked much better for some reason.
victor
