Need help in configuring HyperV VM to have their own VLAN ID to work with cisco SF300 and Sonic wall TZ205
servicel1
I am trying to setup my VM to operate on their own VLAN ID so that they are isolated from each other in terms of networking.
I have a hyperV 2012 server, cisco sf300-24 (layer 2 mode) and a sonic wall.  I want to have each VM on its on separate subnet, isolated from each other using VLAN IDs.  I believe I am stuck at setting up the switch and sonic wall to accept this traffic from the server.
I have already assigned a VLAN ID to each VM on the server but I am not sure on my setup on the switch.  I believe, I have to setup the port that is connected to the server as a Trunk so that it can handle the multiple IDs and then another port that is connecting to the Sonic wall as a Trunk as well.
I am also using the GUI to do this on the switch.
Is there a guide that I can follow or someone point me away on a path?
servicel1
is this possible without a managed switch and only 1 physical nic?
