need help in eigrp key chain
Dr.X
Level 7
Level 7
heloo brothers , this is my 1st poet here is cisco fourms
assume that i have the scinerio as shown:
R1---------------------------R2
now i want to use key chain to perform authentication between routers
assume i created on R1
key chain ahmd
key 1
key-string 123
exit
key 2
key-string 1234
and i used the authentication mode md5 & the correct key chain name ahmd
on the other side on R2
assume i created
key chain ahmad1
key 10
key-string 123
exit
key 30
key-string 1234
and i used the authentication mode md5 & the correct key chain name ahmd1
my question is why the authentication will fail?????????
i understood that when i transmit i use the lowest key which is key 1 in R1 & key 10 in R2 , and when recive i will check all the vaild key,
in R1 the vaild keys are KEY 1 & KEY2  so when it revive the key 10 from R2 with password 123 it is the same as the key 1 and vice versa
so why the authentication faild ??????
i read from the book that the key number has  not to be matched on both routers , but i could make an authentication only when the key number are matched
can any one help me where i have the miss understood??
thanks soo much bro
5 Replies 5
Eugene Khabarov
Level 11
Level 11
Hi! Maybe you have an error in your configuration? Please paste it here.
Also debug eigrp packet will be very helpful and informative to determine reason why authentication fails. Also please enable it and paste output here.
___
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer."
on R1
Current configuration : 727 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
key chain cisco
key 10
   key-string 123
key 20
   key-string 1234
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
ip authentication mode eigrp 1 md5
ip authentication key-chain eigrp 1 cisco
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
auto-summary
ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
on R2
Building configuration...
Current configuration : 723 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
key chain ahmd
key 1
   key-string 123
key 2
   key-string 1234
ip address 10.0.0.2 255.255.255.0
ip authentication key-chain eigrp 1 ahmd
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
auto-summary
ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
why the authentication faild??????
should i use the same key number and the same key-string on the two routers to solve the issue??
thanks bro for ur intersting
Ahmed,
You need to use the same key-string on both routers.
thanks all
i ve just found that there is a typo in the book of cisco
the correction is that we must use the same key number and the same key string in the two routers
not as what was said that """ key number is not critical""
thnaks all for ur replies
Ahmed, debug shows it very clearly:
EIGRP: pkt authentication key id = 10, key not defined or not live
___
