Need Help in LAN Configuration
ErwinMerioles
Good day networking gurus!
I was designing a Network using Packet Tracer 4.0. Unfortunately, I came across a dead-end. I cannot think of a way to let two Routers communicate.
Here is the format.
Executive Computer
Executive Router
Managerial Router A Managerial RouterB
Managerial Computer Managerial Computer
I am pursuing this angle because when I tried putting a switch between the Managerial Routers and the Executive Routers but to no avail.
Subnet: 255.255.240.0
IPs:
Executive Comp - 143.99.16.2
Executive Router 0/0 - 143.99.16.1
0/2 - 143.99.32.1
Managerial Router A 0/0 - 143.99.32.2
0/1 - 143.99.48.1
Managerial Computer A - 143.99.48.2
I have not yet setup Mangerial B. MC A does not ping the Executive Router.
Thanks in advanced.
Erwin Merioles
Rajat Chauhan
Hi Erwin,
I suggest you get some outputs , may be just a "sh run" from the 2 routers.
I hope you have already checked the configs from ground-0 level.
Rajat Chauhan
