I am about to upgrade a router from 3925 to new ISR 43xx however i am facing problem in command below as it seems it is not available anymore in new ISR.. (those in red)
is there any way that i can configure rate limit in ISR to acomplish requirements? Thanks in advance
interface GigabitEthernet0/0
ip address 123.123.123.2 255.255.255.252
ip nat outside
rate-limit output access-group 1 5000000 8000000 9000000 conform-action transmit exceed-action drop
rate-limit output access-group 2 5000000 8000000 9000000 conform-action transmit exceed-action drop
