Need help in terminal
vandongmt1
Hi there, I have issuse. I think it is simple I can't enable interface in terminal. I am using Cisco packet tracer on my Macbook. What should I do? Please help me, tomorrow I have a test in that.
vandongmt1
It seems that I have found a solution, the reason is because I do not turn on the US keyboard because I think that the Vietnamese keyboard I use still has Latin letters but it is not accepted in the terminal, it requires ASCII and the Vietnamese keyboard does not have that. Even so, I thank you for helping me.
6 Replies 6
balaji.bandi
what device is this ? show version ouput
if there is no configuration you should get enable issue command to #
BB
Cisco Packet Tracer 8.1.1 and my Macbook is MacOs Ventura 13.5.2
As you can see, there aren't # after that :(((
post your zipped Packet Tracer project (.pkt) file...
here is this
vandongmt1
