Need help in Troubleshooting ISDN over chap authentication !!!
Dr.X
Level 2
Level 2
hi all ,
i ahve router to get negotiated ip from isp by issdn bri interface :
i have :
Router#sh isdn st
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 77, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHEDi have
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000003
    Internal Multi-drop Termination is ENABLED
    Total Allocated ISDN CCBs = 0
it seems that i have L3 issue ,
i can see that L1,L2 is fine , but L3 dont have active calls ,
i tried ping to initittae traffic but still no benefit :
i have the following running config :
Building configuration...
Current configuration : 3923 bytes
ip source-route
ip cef
no ipv6 cef
isdn switch-type basic-net3
license udi pid CISCO892-K9 sn FCZ1739906V
username admin123 privilege 15 secret 4 ruifghdjksdjkfgsdhjfgsdjfghsd
username xxxxxxxxxx password 0 xxxxxxxx
interface BRI0
ip address negotiated
encapsulation ppp
dialer pool-member 1
isdn termination multidrop
isdn point-to-point-setup
ppp authentication chap
ppp multilink
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
encapsulation ppp
dialer in-band
dialer string 600200000
dialer string 600200005
dialer load-threshold 1 either
dialer-group 1
keepalive 10 3
ppp chap hostname xxxxx
ppp multilink
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
i have debug here :
Router#debug isdn  q921
debug isdn q921 is              ON.
Router#debug isdn  q931
debug isdn q931 is              ON.
Router#
Router#
Router#ping 64.55.45.8
Sending 5, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Mar  3 09:35:33.359: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=77 nr=0
Mar  3 09:35:33.363: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=77 nr=0
Mar  3 09:35:33.363: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=77 nr=0
Mar  3 09:35:33.375: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=77 nr=0.....
Success rate is 0 percent (0/5)
Router#
Mar  3 09:35:43.379: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=77 nr=0
Mar  3 09:35:43.379: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=77 nr=0
Mar  3 09:35:43.379: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=77 nr=0
Mar  3 09:35:43.399: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=77 nr=0
hereis debug all isdn result :
Router#ping
Mar  3 09:36:43.471: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Mar  3 09:36:43.471: ISDN  L2_CODE: l2_timer()
Mar  3 09:36:43.471: ISDN  Q921d: l2_timer: timer (0x87EC445C), timer_type (0x1250)
Mar  3 09:36:43.471: ISDN BR0 L2_CODE: L2IF_GetDriverID()
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_SendprimPkt:
        source_id (0x20A), state (0x7), dest_id (0x200), event (0x140),
        sapi (0x0), ces (0x1),  call_id (0x0),
        chan_id (0x0), int_id (0x87749534), free_p (0x1), pkt (0x877752D0), msecs (0x0), priority (0xA)
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_SendPkt:
        chan_id (0x0), int_id (0x87749534), free_pkt (0x1),
        pkt (0x87DBCBA4), msecs (0x0), priority (0xA)
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F4A5818), size (4)
Mar  3 09:36:43.471:    009B0101--0000009D
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_SendPkt: Sending from L2
        dest_id = 0
Router#ping 131, source_id = 522, prim = 140
        priv_ln = 4, int_id = -2022402764
  datastart = 1F4A5808, netstart = 1F4A5818, datasize = 20
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F4A5808), size (20)
Mar  3 09:36:43.471:    877495340000020A0140040000010603009B0101--000002BC
Mar  3 09:36:43.471: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Mar  3 09:36:43.471: ISDN BR0 PACKET: handle_l2d_srq_mail: received:
        dest_id = 0x0000, source_id = 0x020A, prim = 0x0140
        priv_ln = 4, int_id = 0x87749534, datasize = 4
        line_status[0] = IF_ACTIVE
Mar  3 09:36:43.471: ISDN BR0 Q921r: User TX ->
Mar  3 09:36:43.471: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Mar  3 09:36:43.471: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Mar  3 09:36:43.471: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
Mar  3 09:36:43.471: ISDN BR0 Q921r: User RX <-
Mar  3 09:36:43.471:    029B0101--0000009F
Mar  3 09:36:43.471: ISDN BR0 Q921d: process_rxdata: Frame sent to L2
        source_id (0x200), state (0x0),
        dest_id (0x20A), event (0x141),
        sapi (0x0), ces (0x0), call_id (0x0),
        pkt (0x8A127D94), msecs (0x0), priority (0xA)
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D2CF4), size (4)
        dest_id = 0, source_id = 512, prim = 141
  datastart = 1F2D2CE4, netstart = 1F2D2CF4, datasize = 20
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D2CE4), size (20)
Mar  3 09:36:43.471:    87749534000002000141040000000600029B0101--000002B1
Mar  3 09:36:43.471: ISDN  Q921d: isdn_from_driver_process: event_count 1
Mar  3 09:36:43.471: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
Mar  3 09:36:43.471: ISDN BR0 PACKET: handle_mail: received:
        priv_ln = 4, int_id = -2022402764, datasize = 20
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D2CF4), size (20)
Mar  3 09:36:43.471:    029B0101266DA049E97630DD0000000000000000--00000487
Mar  3 09:36:43.471: ISDN BR0 PACKET: handle_mail: received data =
        source_id (0x20A), state (0x8), dest_id (0x200), event (0x140),
        chan_id (0x0), int_id (0x87749534), free_p (0x1), pkt (0x877752B0), msecs (0x0), priority (0xA)
        pkt (0x87DBD060), msecs (0x0), priority (0xA)
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F4A5958), size (4)
        dest_id = 0, source_id = 522, prim = 140
  datastart = 1F4A5948, netstart = 1F4A5958, datasize = 20
Mar  3 09:36:43.471: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F4A5948), size (20)
Mar  3 09:36:43.471:    877495340000020A0140040000010603029B0101--000002BE
Mar  3 09:36:43.475: ISDN BR0 Q921r: User TX ->
Mar  3 09:36:43.475:    029B0101--0000009F
Mar  3 09:36:43.475: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Mar  3 09:36:43.475: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Mar  3 09:36:43.491: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
Mar  3 09:36:43.491: ISDN BR0 Q921r: User RX <-
Mar  3 09:36:43.491:    009B0101--0000009D
Mar  3 09:36:43.491: ISDN BR0 Q921d: process_rxdata: Frame sent to L2
Mar  3 09:36:43.491: ISDN BR0 PACKET: L2IF_SendPkt:
        pkt (0x8A128250), msecs (0x0), priority (0xA)
Mar  3 09:36:43.491: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D33D4), size (4)
Mar  3 09:36:43.491: ISDN BR0 PACKET: L2IF_SendPkt: Sending from L2
  datastart = 1F2D33C4, netstart = 1F2D33D4, datasize = 20
Mar  3 09:36:43.491: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D33C4), size (20)
Mar  3 09:36:43.491:    87749534000002000141040000000600009B0101--000002AF
Mar  3 09:36:43.491: ISDN  Q921d: isdn_from_driver_process: event_count 1
Mar  3 09:36:43.491: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
Mar  3 09:36:43.491: ISDN BR0 PACKET: handle_mail: received:
Mar  3 09:36:43.491: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D33D4), size (20)
Mar  3 09:36:43.491:    009B010150542014E97600000000000000000000--000002D4
Mar  3 09:36:43.491: ISDN BR0 PACKET: handle_mail: received data =
Mar  3 09:36:43.491: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Mar  3 09:36:43.491: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Router#ping 131.
Router#ping 131.
Mar  3 09:36:53.487: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
Mar  3 09:36:53.487: ISDN BR0 Q921r: User RX <-
Mar  3 09:36:53.487:    029B0101--0000009F
Mar  3 09:36:53.487: ISDN BR0 Q921d: process_rxdata: Frame sent to L2
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_SendPkt:
        pkt (0x8A12870C), msecs (0x0), priority (0xA)
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D3AB4), size (4)
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_SendPkt: Sending from L2
  datastart = 1F2D3AA4, netstart = 1F2D3AB4, datasize = 20
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D3AA4), size (20)
Mar  3 09:36:53.487:    87749534000002000141040000000600029B0101--000002B
Router#ping 131
Mar  3 09:36:53.487: ISDN  Q921d: isdn_from_driver_process: event_count 1
Mar  3 09:36:53.487: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
Mar  3 09:36:53.487: ISDN BR0 PACKET: handle_mail: received:
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1F2D3AB4), size (20)
Mar  3 09:36:53.487:    029B0101266DA049FB55E07E0000000000000000--000004C9
Mar  3 09:36:53.487: ISDN BR0 PACKET: handle_mail: received data =
Mar  3 09:36:53.487: ISDN BR0 L2_CODE: L2IF_GetDriverID()
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_SendprimPkt:
        pkt (0x86DEC768), msecs (0x0), priority (0xA)
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1E701B98), size (4)
  datastart = 1E701B88, netstart = 1E701B98, datasize = 20
Mar  3 09:36:53.487: ISDN BR0 PACKET: L2IF_DispPak: packet - start(1E701B88), size (20)
Mar  3 09:36:53.487:    877495340000020A0140040000010603029B0101--000002BE
Mar  3 09:36:53.487: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
Mar  3 09:36:53.487: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Mar  3 09:36:53.487: ISDN BR0 PACKET: handle_l2d_srq_mail: received:
Mar  3 09:36:53.487: ISDN BR0 Q921r: User TX ->
Mar  3 09:36:53.487: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
Mar  3 09:36:53.491: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)1.un all
any help ??
what could be the problem ??
may be from hostname ?
fron user & pass ?
grom dial string ??
any help ?
5 Replies 5
Dragan Ilic
Level 4
Level 4
Could you post "debug ppp negotiation" and "debug ppp authentication"?
Also I don't thin you need "ppp multilink" and "ppp authentication" under interface bri...
HTH,
Dragan
HTH,
Dragan
I see in the config that Dialer1 is set to authenticate using Chap and that a hostname is supplied. But I do not see anything that supplies a password to be used in the Chap authentication.
Rick
Rick
hi ,
thans alot for you both DARGAN & RICK
actually there was a forgotten command under the dialer 1 interface
i was supposed to add pool under the interface
after i did it ,
isdn is up and every thing was fine
agian ,
im appreciating your time both for help
regards
I am glad that you got it worked out and that our responses were helpful. Thank you for posting back to the forum to tell us that you have resolved it and what you did to solve the problem. That kind of feedback is helpful to other participants in the forum.
Rick
Rick
hi richard ,
i added :
dialer pool 1
regards
