Question on 4507 uplink ports
waqas gondal
The supervisor for the 4507/4510, the 8E, has 8 10Gb uplinks. Are those uplinks suitable as access ports for Servers or VMware hosts, or are they only for inter-switch links?
Waqas
Reza Sharifi
You can use them for whatever you like.  They can connect to VMs, standalone server, workstation, inter-switch etc... They can also be access port or trunk ports.
Reza Sharifi
Thanks Reza
