Need help on IP Access-list
Sukanta Biswas
Is there anyone can advice on the following:?
Source add: 192.168.29.30 (application)
destination add: 192.168.25.17 (Domain controller)
Port: 53
there is only one outbound IP access-list applied on source vlan. How can i allow the DNS traffic from the above mentioned source to destination? Would that be like this below?
permit tcp host 192.168.25.17 eq domain host 192.168.29.30
permit udp host 192.168.25.17 eq domain host 192.168.29.30
or
permit ip host 192.168.25.17 any
any advice would be greatly appreciated...
Sukanta
Sukanta
You are right as long as the access-list is applied outbound on the L3 vlan interface for the 192.168.29.0/24 subnet.
DNS can use either UDP or TCP. Generally it uses UDP which is by far the commonest but if the reply is too long it can use TCP.
Jon
8 Replies 8
ameya_oke
Hi Sukanta,
Your concern is  the reverse packet as ACL is applied in out direction on LAN.
Reverse Packet:
Source: 192.168.25.17
Destination: 192.168.29.30
Port: NA(any random, and not 53)
so below ACL wont work as reverse packet with source 192.168.25.17, dest port wont be 53 rather it would be a random port.
"permit tcp host 192.168.25.17 eq domain host 192.168.29.30
permit udp host 192.168.25.17 eq domain host 192.168.29.30"
Again if you use " permit ip host 192.168.25.17 any" all traffic from DNS is open for accessing ur LAN 192.168.25.0/24 and other subnets as well, which is not efficient
Solution:Use specific host matching clause in ACL.
permit ip host 192.168.25.17 host 192.168.29.30.
Kindly provide your rating only if it help fully.
Ameya
Hi Ameya,
Thank you very much for your advice.
On my access-list I am actually allowing reverse traffic from 192.168.25.17 (with source port 53) to 192.168.29.30 (With random port) using the below entry
permit tcp host 192.168.25.17 eq 53 (source port) host 1092.168.29.30 (using random port)
Am i not right? little confused. Please suggest.
Sukanta
Sukanta
Jon
Ameya
but the acl line above is not specfying a destination port of 53. It is saying -
allow traffic from 192.168.25.17 from port 53 to the host 192.168.29.30 to any random port. Which is correct because the source port from the domain controller for DNS query will be port 53.
Jon
Cisco support community is amazing, within a week many of my misconceptions are removed.
Thanks Jon for your valuable inputs.
Ameya
Ameya
Yes, that's one of the reasons i contribute to CSC as well, you always keep learning
Jon
Also I believe most importantly CSC helps one improve the skill of framing a question.
Technical writing is one aspect which even the most technically sound professionals find difficult.
I guess half the battle is lost if the question can not be understood.
Anyways,Thank you so much!!
Ameya.
Thank you so much both of you. Yes, Jon is right. I think CSC is one of best forum to learn..
Thanks guys.
cheers
sukanta
