need help pinging www.branchtf.com
cyberch000
Hi, I'm new to Cisco Packet Tracer and trying to do an assignment where I ping www.branchtf.com from Laptop0 but it keeps saying request timed out.
My next problem is I setup email on a PC and a laptop and need to send an email from the laptop to the PC but that is also timing out.
I just cannot for the life of me figure out what I have connected or setup improperly. Any help would be much appreciated and sorry if I sound dumb, first time using it. Let me know if more information is needed.
@cyberch000
 Wireless router in PacketTracer is a bit buggy and tricky. But, basically you need to setup the EMAIL clients properly.
For  PC
For Laptop
9 Replies 9
Mark Elsen
          - FYI : Community group for Packet Tracer project questions
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for that, I have posted it in the community group
@cyberch000
For  PC
For Laptop
Thank you so much for that, I was racking my head on why it wasn't working
Would you know how I would be able to find the Serial No.- Configuration - Boot up Sequence - Test Logs on the BranchSrv, BranchPr and Router without CLI - Would I use the command prompt?
Sorry, dont get it. What do you need from router and from server?
I need to find the Serial Number, Firmware version, Configuration settings, boot up sequence and test logs for these devices.
For the BranchR - Router I was able to access the CLI tab and do the command "show version" which showed all the details necessary but I am unable to do this for the other devices as they don't have a CLI tab.
Router and switch you should be using the show version.  For server I dont believe they have those information on it.
For the wireless router I can see the firmware but not the other information
thank you for that, that helps
