Need help: Port forwarding for local website on Cisco 1841
aftabalam_syed
I am trying to do port forwarding for our LAN website as per below configuration but only port 80 is not working and 1723 port forwarding working very fine.
We have done very basic configuration in this router and all security done on firewall (192.168.20.1)
Current configuration : 1906 bytes
version 12.4
service password-encryption
hostname Falcon-ADSL
boot-start-marker
boot-end-marker
enable secret 5 $1$TIBS$V3.Nxy/hgu4NIp3lXkU8E.
enable password 7 0002120A075405
no aaa new-model
resource policy
ip cef
ip flow-cache timeout active 1
ip name-server 213.42.20.20
ip name-server 195.229.241.222
vpdn enable
vpdn-group 1
interface FastEthernet0/0
ip address 192.168.20.200 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
ppp authentication pap chap callin
ppp chap hostname falconrk
ppp chap password 7 055C0B5B2C14435013
ppp pap sent-username falconrk password 7 091B435D145D1A4B01
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.0.0 255.255.240.0 192.168.20.1
ip route 192.168.50.0 255.255.255.0 192.168.20.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.20.111 1723 interface Dialer1 1723
ip nat inside source static tcp 192.168.20.111 443 interface Dialer1 443
ip nat inside source static tcp 192.168.20.111 80 interface Dialer1 80
access-list 1 permit 192.168.0.0 0.0.15.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit any
snmp-server community FTIRAK RO
snmp-server community FTIRAKP RO
control-plane
line con 0
line aux 0
line vty 0 4
password 7 021201481F575D72181B
login
scheduler allocate 20000 1000
end
mfurnival
Level 4
Level 4
Can you enable "debug ip nat" and try and connect and post the output here?
blau grana
Level 7
Level 7
Is it possible that problem is with web server? Did you check this possibility?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
