need help removing stack membership of a secondar Cisco 3750 to become standalone with primary missing!?
m-abooali
Level 4
Level 4
Hello folks,
i have purchased a Cisco 3750 switch for my Cisco lab works from Amazon. now, i see that it was once a secondary sw to a stack. it asked for username and pass so I wen through recovery process and also renamed confix.text and created a new config. I even did "wr erase". now that I have access to the switch, it still thinks it is a secondary sw and I can rename or re-provision it to become standalone. it wont allow.all fa interfaces still says interface FastEthernet2/0/1 - 48.
is there any way that I can make this correct? or i file for a return of the sw.
I have done all tricks that I know with no result but being able to login and create new config.
Please advise,
Masood
Could you please share the: show switch output? You could have a switch as provisioned status, so you could execute:
no switch <switch numer> provisioned
like
no switch 3 provisioned
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
6 Replies 6
like
Hi Julio,
thanks for responding. below is the sh switch output. the fist line with "*" was added by me but the second line switch 2 ane with the switch and even "wr erase" did not get rid of it. I will try your commands altho I think I have done that to make the first line command
real-sw1#
real-sw1#
real-sw1#sh switch
Switch/Stack Mac Address : 001a.e36d.1e80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 001a.e36d.1e80     1      0       Ready
 2       Member 0000.0000.0000     0      0       Provisioned
real-sw1#
Masood
Hello again.
the command did it.
real-sw1#
but still showing int fa2/0/x !?
Masood
did it!
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
BUT
despite executing "Ip routing" command, I get this:
real-sw1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
real-sw1(config)#ip routing
real-sw1(config)#exit
real-sw1#sh
03:16:07: %SYS-5-CONFIG_I: Configured from console by console ip eigrp neigh
IP-EIGRP neighbors for process 1
real-sw1#ping 192.168.13.1
% Unrecognized host or address, or protocol not running.
real-sw1#
thank you,
Masood
Hi Julio,
also, these vlans came with the switch. when at the recovery process I deleted vlan.dat file from flash but it did not get rid of these vlans
2    DATA_VLAN                        active
3    VMWARE_LAN                       active
4    FW_Link                          active
VLAN Name                             Status    Ports
5    VMWARE_LAN2                      active
6    NETSCALER_VLAN                   active
7    ILO_VLAN
any suggestions please?
Best Regards,
Masood
reloaded and ip routing started to work.
still cannot get rid of those vlans!?
I am sorry for multiple question. they came up as I was working on the switch. I got it late this afternoon and stated working on it.
regards,
masood
