need help with acl for rdp
adam.mcdonald
i am looking to create an acl to block all traffic except for remote desktop connections to an interface on a cisco 3640
the total network is basically a 10.0.0.0 and the network for the interface is 10.101.150.0
Jon Marshall
Hi Adam
It's not clear what you mean by an interface on the router. The following access-list would only allow rdp connections but it's a little difficult to suggest which interface to apply it to and in which direction.
access-list 101 permit tcp any 10.101.150.0 255.255.255.0 eq 3389
access-list 101 deny ip any any
int fa0/0
ip access-group 101 out
This assumes the network 10.101.150.0 is connected to the fa0/0 interface on your router.
The above access-list will only allow traffic sent to a host on 10.101.150.0 network on port 3389. It will block everything else.
Jon
sorry i should have been a little more specific. the interface would be fastethernet 0/1 and i want to limit all inbound and outbound traffic
joshdloan
access-list 110 permit tcp 10.0.0.0 0.255.255.255 host 10.101.150.0 0.0.0.255 eq 3389
apply it to the interface
oops.. too much time on the PIX. those wild card masks should be reversed. 255.0.0.0.0, etc
