I been working on this all night cant seem to make it work. I cant find where i made a mistake. it would be nice is someone where to help me.
Topology:
Tables:
Condition:
S1
- Configure, name and assign VLANs. Ports should be manually configured as access ports.
- Configure trunking.
R2
- Configure hostname and ip address interfaces
- Implement routing: (OSPFv2 AND OSPFv3)
- Use OSPF process ID 2 and router ID 2.2.2.2
- Disable interfaces that should not send OSPF messages.
- Configure a default route to the Internet.
- Propagate the default route
- Configure authentication (password: CISCO)
- Implement NAT:
- Configure a static NAT for the server using the public ip address 219.1.1.5
- Configure a standard, one statement ACL number 2. All IP addresses belonging to the R1 and R2 network
- Configure dynamic NAT with PAT using a pool name of your choice and these two public addresses: 219.1.1.1/30 and 219.1.1.2/29
R1
- Configure inter-VLAN routing.
- Configure DHCP services for VLAN 2 and 3. Use LAN3 and LAN2 as the case-sensitive name for the pool.
- Use OSPF process ID 2 and router ID 1.1.1.1
ISP
- Configure hostname and IP address interfacesG-
- Configure a static route to reach the public addresses assigned to R1 and R2 network.
All devices should now be able to ping all other devices. If not, troubleshoot your configurations to isolate and solve problems. A few tests include:
- Verify DHCP assigned on PC1, PC4
- Verify remote access to S1 by using SSH from PC2.
- Verify VLANs are assigned to appropriate ports and port security is in force.
- Verify OSPF neighbors and a complete routing table.
- Verify NAT translations and statics.
S1
en
config t
vlan 2
name servers
vlan 3
name SALES
vlan 4
name Native
vlan 5
name Management
int fa0/1
sw mode access
sw access vlan 3
int fa0/2
sw mode trunk
sw trunk allowed vlan all
int fa0/3
sw mode access
sw access vlan 3
int fa0/4
sw mode access
sw access vlan 2
int vlan 2
int vlan 3
int vlan 4
int vlan 5
ip add 192.168.5.2 255.255.255.0
R2
en
config t
hostname R2
int G0/0
ip add 192.168.6.1 255.255.255.0
ipv6 add 2009::1/64
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 CISCO
ipv6 ospf 1 area 0
ip nat inside
no shut
int S0/0/0
ip add 210.1.1.1 255.255.255.252
ipv6 add 2002::3/64
ipv6 ospf 1 area 0
ip nat inside
no shut
int S0/0/1
ip add 210.1.1.5 255.255.255.252
ipv6 add 2004::1/64
ip nat outside
no shut
exit
router ospf 1
network 210.1.1.0 0.0.0.3 area 0
network 192.168.6.0 0.0.0.255 area 0
router-id 2.2.2.2
passive-interface g0/0
passive-interface S0/0/1
default-information originate
exit
ipv6 unicast-routing
ipv6 router ospf 1
router-id 2.2.2.2
exit
ip route 0.0.0.0 0.0.0.0 s0/0/1
ipv6 route ::/0 s0/0/1
ip nat inside source static 210.1.1.0 219.1.1.1
ip nat inside source static 192.168.6.0 219.1.1.2
access-list 2 permit 210.1.1.0 0.0.0.3
access-list 2 permit 192.168.6.0 0.0.0.255
ip nat pool NATP 219.1.1.1 219.1.1.5 netmask 255.255.255.248
ip nat inside source list 2 pool NATP
R1
en
config t
int G0/0.2
encapsulation dot1Q 2
ip add 192.168.2.1 255.255.255.0
ipv6 add 2005::1/64
int G0/0.3
encapsulation dot1Q 3
ip add 192.168.3.1 255.255.255.0
ipv6 add 2006::1/64
int G0/0.4
encapsulation dot1Q 4
ip add 192.168.4.1 255.255.255.0
ipv6 add 2007::1/64
int G0/0.5
encapsulation dot1Q 5
ip add 192.168.5.1 255.255.255.0
ipv6 add 2008::1/64
int G0/0
no shut
int S0/0/0
ip add 210.1.1.2 255.255.255.252
ipv6 add 2002::2/64
no shut
ip dhcp pool LAN2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
exit
ip dhcp pool LAN3
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
exit
router ospf 1
network 210.1.1.2 0.0.0.3 area 0
network 192.168.2.1 0.0.0.255 area 0
network 192.168.3.1 0.0.0.255 area 0
network 192.168.4.1 0.0.0.255 area 0
network 192.168.5.1 0.0.0.255 area 0
router-id 1.1.1.1
passive-interface default
no passive-interface S0/0/1
exit
ipv6 router ospf 1
router-id 1.1.1.1
exit
ISP
en
config t
int G0/0
ip add 210.1.1.1 255.255.255.224
ipv6 add 2004::1/64
no shut
int s0/0/1
ip add 210.1.1.6 255.255.255.252
ipv6 add 2003::3/64
no shut
exit
default route 0.0.0.0 0.0.0.0 s0/0/1
