Need help with l3 intervlan routing
I want to route between vlans using layer 3 switches and also route from the vlan to router 0
So i have configured the vlans on sw1 and sw2, i have also configured SVI for all vlans on L3 switches
i have enabled routing already, trunk have been configured
but when i check the routing table only int vlan 1 appears
how can i configure this ?
Help! thank you
paul.driver
Hello
Is this a packet tracer lab, if so can you attach this labs file.
EDITED -Please  ignore the post below - Cisco are doing something with my profile and for some temporary time i lost all my posts for the passed 10 years! I didn't realize until I replied to your post .
Kind Regards
Paul
Martin L
check L3 SVI state UP? with show ip interface brief command.   is it UP UP?
you may need a host for vlan x to bring SVI x to UP/UP state.  Note that PT does not have auto-state exclude command that would let us keep SVI UP while there are no hosts connected to vlan / switch or hosts are down (turned off).
Also, double check vlans are present in the vlan database and allowed on trunks.
Regards, ML
**Please Rate All Helpful Responses **
