Need Info regarding Cisco Switch
Daanial Farrukh
Hello all, I require information regarding Cisco Switch which have following specs:
1. 24 or 48 SFP ports
2. Switching capacity of around 600 Gbps - 700 Gbps
3. Forwarding Packets around 100 - 150 Mpps
Thanking in anticipation.
15 Replies 15
Mark Elsen
 - You may for instance , start here : https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
already tried it but coudn't find any switch in this range
Leo Laohoo
What is the budget?
just for educational purpose
Just educational' I think this is high capacity not need for educational.
You can go to 9200 compact it low price give you 24 or 48 ports.
sorry for the miscommunication, educational means that I am a technical trainer and one of my students is making a list of switches, so he was asking for any cisco switch in this range. Thankyou.
yes ports and switching capacity is ok but forwarding rate is 476.19 Mpps which is out of range. Thankyou for your kind effort.
Your next option would be 9500
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9500-series-switches/nb-06-cat9500-ser-data-sheet-cte-en.html
Or you need to start think in Nexus switch and not Catalyst anymore.
Cisco switches its been with a very few option this days.
its even more away from 9300 having switching capacity 960 Gbps and Forwarding 720 Mpps packets.
Then I believe you need to start looking into Nexus line.  Catalyst I dont believe will be enough.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-741336.html
Looked into it already, Switching Capacity is ok but forwarding packets per second (Mpps) out of range. Thankyou.
Forwarding packets capacity is out of range. Thankyou
