VTP domain management network adding Juniper switch
dazza007
Level 2
Level 2
I have a question about adding a new switch to our fleet of cisco switches and having issues in that I am trying to get routing via a cisco core on a Juniper switch via the cisco management vlan
The switch has a VTP domain with its interface setup as the management vlan.
I can only get traffic via the management vlan by adding the VTP credentials to a cisco new switch and adding the vlan onto the switch and putting a static route on the switch to the core. I don't have this option with a non-cisco switch. The core is set as a server in version 1.
I managed to get vlan information from the cisco core on the Juniper switch but cannot get traffic between the locally connected cisco core from the juniper core. I have next-hopped to the firewall, but would like to next-hop to the routing on the cisco core.
I understand that Cisco is proprietary and have setup a working trunk for a migration, but is there something I am missing about routing to the local switch.
This is what I have tried
switchport trunk allowed vlan 100-103,110,304,911,996-999
switchport trunk native vlan <management vlan>
switchport mode trunk
switchport nonegotiate
no cdp enable
juniper EX4600 (ELS)
native-vlan-id <management vlan>;
unit 0 {
family ethernet-switching {
interface-mode trunk;
vlan {
members [ DomainServices Firewall HyperVMgmt ilo Management migration native Voice Wired3 Wired4 Cisco ];
The Juniper has vstp vlan/interface all
With a route 0.0.0.0/00 <local cisco management ip>
Any ideas are welcome
6 Replies 6
Can I see show interface trunk
This is what i have with a different native vlan.
sh interfaces te1/7 trunk
Port Mode Encapsulation Status Native vlan
Te1/7 on 802.1q trunking 998
Port Vlans allowed on trunk
Te1/7 100-103,110,304,710,911,996-999
Port Vlans allowed and active in management domain
Port Vlans in spanning tree forwarding state and not pruned
Te1/7 911
As I guess' vtp pruned the vlan from trunk.
Disable pruned ( not recommend if other SW use it)
Or use
Switchport trunk pruning vlan add x y z
Also for native I dont get' is it match or not in both side ?
Thank you
There is pruning, Upon enabling the interface, I see a broadcast (ffff.ffff.ffff.ffff) and then see mac addresses then they vanish.
For compatibility I am running VSTP on the Junos however there is evidently incompatibility on the native vlan and vlan 1 on cisco and junos. (Vlan 1 is shutdown on the Cisco core) It is suggested that native vlans and vlan 1 should run RSTP on Junos.
In order to get STP to work
miaalice405
Community Member
I'm aslo facing same issue from couple of days, Did you get any answer yet?
@MHM Cisco World is correct about disabling VTP pruning. If everything doesn't run VTP, then pruning will not work correctly. I haven't used the "Switchport trunk pruning vlan" commands, so you should look those up. You can also disable pruning globally.
