need module for cisco 7604 that supply QOS !!
Dr.X
Level 2
Level 2
hi ,
i have cisoc MLS 7604 ,
it dont allow QOS
im looking for module to buy it , but i want it to support QOS
is there any modules that support QOS  on cisco 7604 ????
regards
6 Replies 6
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I believe almost, if not all, line cards for 7600s support some QoS features.  However, QoS features are often very limited compared to software based routers, espeically when using "LAN" kinds of line cards.  QoS features do vary between line cards.
The original and enhanced FlexWAN cards support QoS comparable to many software based routers.  Some of the "WAN" link cards, only supported on the 7600 series do support some additional QoS features not found on the "LAN" line cards.  ("LAN" cards generally for high port density copper Ethernet.)
hi  ,
thanks alot for reply ,
i know that it support limited basic QOS ,
but im tryinging to apply policymap that match ips and ports  and support  service policy "in" , "out"  direction
i need to buy that hardware that support  QOS , but i need the know what hardware will help me
here is my current module :
Gateway7600#sh module
Mod Ports Card Type                              Model              Serial No.
  1    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B     SAD104204GX
Mod MAC addresses                       Hw   Fw            Sw           Status
  1  0018.bad2.2324 to 0018.bad2.232f  4.4   12.2(18r)SX   15.2(4)      Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 3       WS-F6K-PFC3B       SAD104201HK  2.3    Ok
  1  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A      SAD104004UC  3.1    Ok
Mod  Online Diag Status
regards
Disclaimer
Posting
The FlexWANs support in and out service-policies.  Unsure what other cards might too.
It would help if you identified what kind of ports you wanted the card to support.
here is sample config that running on 7200 router and want to run it on 7600 MLS :
7200Gateway#sh class-map youtube
Class Map match-all youtube (id 3)
   Match access-group name youtube
7200Gateway#sh ip acce
7200Gateway#sh ip access-lists youtube
Extended IP access list youtube
    10 permit ip xxxxxxxxxxxxxxxx (3441952638 matches)
    20 permit ip xxxxxxxxxxxxxxxxxxxxxxxx (3234212002 matches)
    30 permit ip xxxxxxxxxxxxxxxxxxxxx (7779194 matches)
    40 permit ip xxxxxxxxxxxxxxxxxxxxxxxx (1675711556 matches)
    50 permit ip xxxxxxxxxxxxxxxxxx (1127113112 matches)
    60 permit ip xxxxxxxxxxxxxxxxxxxxxxxx (18582326 matches)
    70 permit ip x5 (2510367971 matches)
7200Gateway#sh policy-map youtube
  Policy Map youtube
    Class youtube
      bandwidth 400000 (kbps)
    Class browsing
      bandwidth 220000 (kbps)
    Class https
    Class dnsqos
      bandwidth 10000 (kbps)
    Class facebookqos
      bandwidth 60000 (kbps)
i wish any module in 7600 that can run my commands above and  want the interfaces to  be 1G ethernet
regards
hi ,
i want ports that support fiber  and at leat 1G traffic .
regards
any suggestion ?
regards
