need SNMP commands to enable in devices routers and switches
praveennoc
Can you help me how to configure SNMP in routers and swithces with help of commands detially.
How to enable traps and what are the min traps require for the device
thanks,
PS
Rate all of the helpful posts!!! Which helps other to find out the right answers.
Karthick Murugan
Thanks & Regards, Karthick Murugan CCIE#39285
6 Replies 6
Karthick Murugan
Hi Praveen,
To complete snmp configuration on a router/switch, we need three component.
1) community-string (Acts like a password)
2) Permission(Read or RW)
3) Server IP(From where the polling happens)
Sample configuration below.
snmp-server host 1.1.1.1
snmp-server community ro -->RO stands for Readonly
snmp-server enable traps(this will enable traps for all supported feature below)
Sample configuration:
snmp-server community karthick RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps dot1x auth-fail-vlan guest-vlan no-auth-fail-vlan no-guest-vlan
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps rep
snmp-server enable traps ether-oam
snmp-server enable traps bgp
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps isis
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps energywise
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps rtr
snmp-server enable traps alarms informational
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 1.1.1.1 karthick
kmuruga2% snmpwalk -Os -c cisco -v 1 10.105.137.5 sysUpTimeInstance
sysUpTimeInstance = Timeticks: (6208631) 17:14:46.31
Hope it helps!!
Karthick Murugan
CCIE#39285
Hi Karthik,
thank you for response .
as you said
snmp-server enable traps- only one command will enable all traps directly or need  to enable above sample traple one by one ?
thank you
PS
Hi Praveen,
I will enable all the traps by itself.
Karthick Murugan
CCIE#39285
thank you for quick response
Hi Praveen,
Anytime!!
Wish you a great day ahead!!
Karthick Murugan
Karthick Murugan
