need some advise on 2960x qos - egress drop packets
kim31
Hi guys,
i need some advise for some catalyst qos.
i have thin wireless AP connected on a cisco catalyst 2960x.
with mls qos disable, i have observed drops on the egress queue 3 weight 2.
the interface's max rx/tx is less than 6mbps, so i am suspecting bursty traffic.
i have been reading some of the related documents and articles, including the following.
therefore, i have tried enabling mls qos and changing the buffers and threshold values using trial and error method.
  • mls qos queue-set output 2 threshold 2 800 400 50 800
  • mls qos queue-set output 2 threshold 4 800 400 50 800
  • mls qos queue-set output 2 buffers 5 45 5 45
the cos/dscp mappings are untouched.
but i still having dropped packets in queue2, threshold 1 and 2.
there are more details in the attached file.
i do have a few queries
  • am i on the right direction to minimise/troubleshoot the packet drops?
  • is there any document/article to fine-tune the buffer and threshold values?
  • is there any way clear the "show platform port-asic stats" counters?
  • in the "show mls qos cos/dscp-output-q", all values are using threshold 1.
    • there are packet drops in queue 1 weight 1 (which should be queue 2 threshold 2 in the output queue), am i correct or missing something?
thanks for any advise/replies in advance.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I noticed "with mls qos disable".
Are you trying these changes with QoS still disabled?  If so, I believe you may need to enable QoS to enable the commands to adjust buffers.
believe so
You've already found what I consider the about best of which I'm aware.
Not that I'm aware of (other than a device reload)
Some of the 3750 queue stats and commands differ on starting with zero or one, might be the case here(?)
thanks for your input
may i know which line/output do you observed that the mls qos disabled?
i have been "playing around" with the values and settings, i might missed something.
From your OP, i.e. "with mls qos disable"
Unclear what the situation is with your log attachment.
