03-11-2015 11:25 AM - edited 03-07-2019 11:03 PM
Need that a Cisco Catalyst Express 500 behaves as cheap switch.
I happen to have a surplus of CE500 and i need to use one as a layer 2 cheap switch (unaware of lan and with port protection off).
How can i achive this?
03-11-2015 11:13 PM
What you mean by unaware of LAN?
If you are just after of a switch that has very basic feature sets and "cheap", then I'd say buy a NetGear or Linksys SOHO switch.
03-12-2015 07:43 AM
That's the thing, i'm sitting on several CE500, i'm not allowed to buy a cheap one right now, i have to use what i have, i know is too much but it should work and i read that it does, there is only one problem, i need to plug a access point to the CE500 that connect this section of my network to the rest.
I can't make the CE500 to work with this AP, a cheap switch i had there before worked properly.
03-12-2015 11:26 AM
Are you doing any VLAN tagging on the AP?
03-11-2015 11:46 PM
By default it will behave like that. The CE500 switches have smart port built in settings for IP phone, uplink and PC. It may be that all the smart ports are set by default to PC. If it is set to anything else like IP phone or uplink, it may not all work. But I think if you just plug it in, and don't configure any management, it will behave like a "Cheap Switch"
03-12-2015 07:38 AM
My problem is an access point that connect this CE500 with the rest of the network, i can't make the switch to recognize it, the dhcp queries aren't passing through.
I tryed setting the port the AP is as switch, access point and other, and nothing works.
Tomorrow i'll try setting the port as router.
