Need to add another FastEthernet or Ethernet to Cisco Router 2620
Mohamed Lotfy
Dear All,
I need you help and advice please.
Now I need to add another Fast-Ethernet or Ethernet to Cisco Router 2620, I’m already purchase Module NM-1FE2W but it wasn’t working with the 2620 Router.
•1- Is there any way to add Module NM-1FE2W to the 2620 Router ?
•2- If No , What’s the best Module that support the 2620 Router and allow me to add more Fast-Ethernet or Ethernet interfaces??
3 Accepted Solutions
Majed Saeed
Hi Mohammad ,
Please check below link includes all interfaces and modules supported by Cisco 2600 platform . As I checked you can get FastEthernet/Ethernet .
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
R,
Majed .
Thanks for your fast reply, but regarding to the document is that mean no way to add the Module NM-1FE2W to the 2620 Router ?
Hmmmm ... There have been people who've added an NM-1FE into a 2600 router.  You'll search/find Cisco documentation that will tell you it will and it WON'T work.  But it can work if the router is an 2600XM.  If your router does not have a built-in fastethernet ports, then it won't work.
If I remembered correctly, for the 2600, NM-1E or NM-4E will work.
Hi Mohammad ,
Actually if check the table which is tagged with LAN Network Modules or LAN and WIC Combo Network Modules , you will get something close to your order .
R,
Majed
Majed Saeed
Hi Mohammad ,
R,
Majed .
Dear Majed,
And can you please for advice me what's the Module that can be compatible with the 2620 Router ?
Hi Mohammad ,
R,
Majed
