Need to allow VLAN at specific link
Mahmoud Marie
I have two PCs connected to the same switch and there are two uplinks to another switch as the below diagram, just need to know how to let VLAN 40 going through "Dark-Fiber-1" Port1 and VLAN30 going through "Dark-Fiber-2" Port-5
Appreciate you help
22 Replies 22
Unfortunately، there is a link between CS-1 and CS-2
so there is any other way to separate the VLAN for each link
Thank you
@Mahmoud Marie wrote:
If I create direct connection between the Layer-2 switch and CS-1 & CS-2 as the below diagram:
How to allow VLAN10 & VLAN20 only from Link-1 and VLAN30, VLAN40, VLAN50 only from Link-2
As you no longer have a possible L2 loop, it's done as both @MHM Cisco World and @paul driver describe in their replies.
Example:
interface FastEthernet0/1
 switchport trunk allowed vlan 10,20
 switchport mode trunk
interface FastEthernet0/5
 switchport trunk allowed vlan 30,40,50
Hello
@Mahmoud Marie  you've change the topology correct?
@MHM Cisco World wrote:
if there is no interconnect between CS-1 and CS-2 then
simple
config link1 as trunk and allow vlan 10,20
config link2 as trunk and allow vlan 30,40,50
It will work if hosts for those vlans dont exist on both CS switch's other wise they will lost connection if you prune off the vlans.
Kind Regards
Paul
Hello @paul driver
I am still trying to find the best way to separate the VLANs
Joseph W. Doherty
So far @Mahmoud Marie you've provided two different topology diagrams and your last two replies seem to recreate the OP topology and say you're still seeking the best way.
For any possible way, we need to know the actual topology and platforms to be used.
BTW, so how would you know the best way?
Thank you @Joseph W. Doherty
Here is the current topology, the "CoreSwitch" is the gateway for VLANs "10, 20, 30, 40, 50"
I need to adding new separate link to move the traffic for VLAN 10 & 20 only as will migrate them to OT gateway. as the below digram:
So Link-1 move the traffic for "VLAN 30, 40, 50" and Link-2 move the traffic for "VLAN 10, 20"
this design is work make review and you are free to ask any Q
please if there is any point not clear ask about it
MHM
Your question has been answered multiple times, with two different approaches and mention of a potential problem if using non-Cisco STP/rapid-STP.
So, did you not understand the different approaches, or is there some reason what has been suggested (by multiple folks) is not acceptable?
