Need to Configure VSS on Cisco 4503E series Switch
I am not able to configure VSS on Cisco 4503E series with WS-X45-SUP8-E sup engine. The "Switch virtual domain" command is not taking, showing unrecognized command...
Looks like you need a minimum XOS 3.6.xE for VSS on a Sup-8e.
http://www.cisco.com/c/en/us/support/ios-nx-os-software/ios-xe-3e/products-release-notes-list.html
Reza Sharifi
Are the VSL links connected?
What is error message when you type?
switch virtual domain xx
Actually, when i put " switch virtual ?"   it is  showing unrecognized command. Even in interface port-channel, "switch virtual link " command is not taking, and exec mode "switch convert mode ?" is also showing unrecognized command...
