Need to connect same IP with different location
mmarie
Hello
I need to connect to the SCADA devices range (192.168.0.X) and we have the same range in different locations, so there are any options to connect to these devices, here is the below topology.
Appreciate your help.
@mmarie hi, if you have any L3 boundaries between buildings, you cannot do that normally. but if you have direct L2 connectivity between building you can. second option is to use overlay technology like VxLAN. it extends VLANs beyond L3 networks.
Good luck
KB
The drawing shows the network connecting through switches. With switches providing connectivity there are not good options for having the same IP networks in different locations, especially if you want to treat them as separate networks. If routers were providing the connectivity it could be possible to set up Network Address Translation and allow the different locations to communicate.
Rick
