Need to do PoE
scott.bridges
Hello's,
I have a couple Cisco AP's I'd like to get going with Power over Ethernet.  Is there any way to tell from "show version" if my switch supports this?  If so, what do I need to do to go about enabling?
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWA
RE (fc1)
2960G uptime is 26 weeks, 1 day, 12 hours, 38 minutes
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.
SE5.bin"
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision E0) with 61440K/4088K by
tes of memory.
Processor board ID FOC1221X0GJ
Last reset from power-on
2 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:21:D7:99:E7:80
Motherboard assembly number     : 73-10015-06
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC12210CEA
Power supply serial number      : DCA1217915B
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C2960G-24TC-L
System serial number            : FOC1221X0GJ
Top Assembly Part Number        : 800-26673-03
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : COM3G00BRB
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   24     WS-C2960G-24TC-L   12.2(35)SE5             C2960-LANBASE-M
Configuration register is 0xF
2960G#
Thanks for any help.
Leo Laohoo
Under "Model Number" your appliance is a WS-C2960G-24TC-L and does not support PoE.  PoE normally have the code "P" after like WS-C2960G-24PC-L.
Just in case, you also verify by using the following commands:
1.  sh inventory - this will give you a brief description of your appliance; and
2.  sh power inline - will tell you if your switch is PoE
