Need to enable telnet through Cisco Network Assistant(CNA)
vigoprince
Hi all,
Before we have telnet access to the switches in our production environment.
But today i found i can't access many switches through telnet. It's rejecting the telent connection.
What have now on hand is i can connect to those switches through Cisco Network Assistant (ver 5.7)
I try to enable the telnet from the CNA but didn't find any option there.
I only found the place where to setup the telent password.
Is it possible to achieve this through CNA or it's an impossible mission at all.
Why i need this because i don't want to go every shopfloor sin our plants to enable this through Console..
Thanks in advance,
Vigo
vigoprince
Anyone can help?
ssavard01
You should be able to enable it in the switch web interface.
roger
Just copy telnet.exe from the Windows\system32 folder to the Windows\SysWow64
Problem solved.
Thanks a lot it has worked
