Need to telnet from PC to Switch 3560
LiamKnipper
I am creating a topology on Cisco Packet Tracer. I have to use two Cisco 3560-24PS switches. I need to be able to telnet from the connect PC to the switch. I know I need to enter a command  specific to 3560 into the switch to allow telnetting but I don't know what it is.
Please help.]
Username mhm password mhm
Enable password mhm
Line vty 0 4
Login local
That what you need
balaji.bandi
i would not suggest to use Telnet since its not that secure, most of live network moved to SSH
but for Lab you testing telnet ok, but you can move to SSH is better option :
simple config should fix the issue :
#config terminal
(config)#enable password mypassword
(config)#line vty 0 15
(onfig-line)#password cisco
(config-line)#login
Note : make sure you configure Interface IP address for you to Login to device using telnet
BB
M02@rt37
Hello @LiamKnipper
Follow this
https://www.letsconfig.com/how-to-configure-telnet-on-cisco-ios-devices/
Note that is better to use SSH instead of TELNET on a security point of view.
Best regards
