10-27-2017 01:45 PM - edited 03-08-2019 12:32 PM
I am assuming I need to update the firmware on my stack and on an unconfigured WS-C3750-24PS-S I want to add to the stack. Presently the stack has SW version 12.2(37)SE and the new switch has 12.2(50)SE3. How do I find the right image to upload and how do I update the firmware without causing problems? I am assuming the firmware has to match to add this switch to the stack?
10-27-2017 03:52 PM
In a stack environment, all switches need to run the same exact IOS verion. So, you have 2 options here, upgrade the stack to 12.2(50)SE3 to match the single switch and than add the single switch to the stack. See link below. Or downgrade the single switch to match the stack, add the switch to the stack and than upgrade the entire stack. Option 1 seems easier. Here is a link on how to add a single switch to a stack:
If you want to install a completely different image you need to go to Cisco site and support the IOS you want and than load it to the switches. in order to download a new IOS, you need a valid service contract and a CCO account.
10-27-2017 04:48 PM
I agree with Reza.
I would also like to add that if it's possible, upgrade the stack IOS. 12.2(50)SE train isn't that stable.
A very, very stable for the 3750-series family of switches is the 12.2(55)SE-train.
10-27-2017 04:51 PM
@Leo Laohoo wrote:
I agree with Reza.
So, I would have to have a current contract to download this though?
10-27-2017 04:59 PM
Yes.
10-27-2017 04:59 PM
@Leo Laohoo wrote:
I agree with Reza.
I do not have a current contract, but even if I did, I don't see my WS-C3750-24PS-S switch listed for this release:
10-27-2017 05:43 PM
Won't make any difference. The entire family share the same code. Just download the correct version. Because this is a "plain" 3750 (non-GigabitEthernet access ports), then the "highest" version this unit can load (due to it's limited flash space) is 12.2(55)SE train. So grab the latest TAR file with this version.
10-27-2017 05:51 PM
@Leo Laohoo wrote:
but even if I did, I don't see my WS-C3750-24PS-S switch listed for this release:Won't make any difference. The entire family share the same code. Just download the correct version. Because this is a "plain" 3750 (non-GigabitEthernet access ports), then the "highest" version this unit can load (due to it's limited flash space) is 12.2(55)SE train. So grab the latest TAR file with this version.
So, I don't have a current contract -- can I pull the 12.2(50)SE file from the newer switch somehow and flash it to the stack so they have the same IOS?
10-27-2017 05:55 PM - edited 10-27-2017 05:55 PM
Yes, you can.
From the existing stack, post the complete output to the command "sh version".
10-27-2017 05:58 PM
@Leo Laohoo wrote:
Yes, you can.
SRSTACK#sh version
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(37)SE, RELEA SE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 10-May-07 16:31 by antonino
Image text-base: 0x00003000, data-base: 0x012C0000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR E (fc4)
SRSTACK uptime is 1 year, 7 weeks, 6 days, 7 hours, 30 minutes
System image file is "flash:c3750-ipbasek9-mz.122-37.SE/c3750-ipbasek9-mz.122-37 .SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-24P (PowerPC405) processor (revision H0) with 118784K/12280K bytes of memory.
Processor board ID CAT1010R2GQ
Last reset from power-on
6 Virtual Ethernet interfaces
72 FastEthernet interfaces
6 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:17:5A:48:80:80
Motherboard assembly number : 73-9672-07
Power supply part number : 341-0029-04
Motherboard serial number : CAT101006CA
Power supply serial number : LIT1005006A
Model revision number : H0
Motherboard revision number : A0
Model number : WS-C3750-24PS-S
System serial number : CAT1010R2GQ
Top Assembly Part Number : 800-25860-03
Top Assembly Revision Number : C0
Version ID : V04
CLEI Code Number : CNMV1K0CRC
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
1 26 WS-C3750-24P 12.2(37)SE C3750-IPBASEK9-M
* 2 26 WS-C3750-24P 12.2(37)SE C3750-IPBASEK9-M
3 26 WS-C3750-24P 12.2(37)SE C3750-IPBASEK9-M
Switch 01
Switch Uptime : 1 year, 7 weeks, 6 days, 7 hours, 30 minutes
Base ethernet MAC Address : 00:1A:2F:CD:39:00
Motherboard assembly number : 73-9672-10
Power supply part number : 341-0029-03
Motherboard serial number : CAT104658AY
Power supply serial number : LIT12330H6L
Model revision number : J0
System serial number : CAT1046NJVH
Top assembly part number : 800-25860-05
Top assembly revision number : A0
Version ID : V06
CLEI Code Number : 456622
Switch 03
Base ethernet MAC Address : 00:1F:6D:F4:8A:00
Power supply part number : 341-0029-05
Motherboard serial number : FDO120511ET
Power supply serial number : LIT12040MCM
Model revision number : R0
System serial number : FDO1205Z62E
Version ID : V06
CLEI Code Number : COMU410ARA
Configuration register is 0xF
10-27-2017 05:59 PM
And this is from the NEW switch:
office#sh version
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 06:19 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02900000
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
office uptime is 3 hours, 14 minutes
System image file is "flash:c3750-ipbasek9-mz.122-50.SE3/c3750-ipbasek9-mz.122-50.SE3.bin"
export@cisco.com.
cisco WS-C3750-24P (PowerPC405) processor (revision H0) with 131072K bytes of memory.
Processor board ID CAT0948R26T
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
Base ethernet MAC Address : 00:16:46:E7:58:80
Motherboard serial number : CAT094713QP
Power supply serial number : LIT094403MS
System serial number : CAT0948R26T
Version ID : V04
* 4 26 WS-C3750-24P 12.2(50)SE3 C3750-IPBASEK9-M
10-27-2017 06:22 PM
flash:c3750-ipbasek9-mz.122-37.SE/c3750-ipbasek9-mz.122-37.SE.bin
You will need to copy this file (above) from the existing stack to the new switch.
10-29-2017 01:07 PM
@Leo Laohoo wrote:
flash:c3750-ipbasek9-mz.122-37.SE/c3750-ipbasek9-mz.122-37.SE.binYou will need to copy this file (above) from the existing stack to the new switch.
Okay, so I have copied this file to my PC via TFTP -- how do I copy it to the appropriate location on the new switch? Is it just switch#copy tftp flash ?
10-29-2017 01:12 PM
Here's the current running configuration on the new switch. Is there anything here that will cause problems when the new switch is connected into the new stack? I'm particularly concerned about these two lines. The new switch had already been numbered 3, and I have renumbered it 4:
switch 3 provision ws-c3750-24p
switch 4 provision ws-c3750-24p
office#sho run
Building configuration...
Current configuration : 4177 bytes
version 12.2
no service pad
service password-encryption
hostname office
boot-start-marker
boot-end-marker
enable secret 5 $1$DAdG$SyR7RwP49Gmb9e1BMhtoU1
username administrator secret 5 $1$Dhij$.s751ysOfpYrF1uqQ3xYO0
no aaa new-model
system mtu routing 1500
ip subnet-zero
crypto pki trustpoint TP-self-signed-1189566592
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1189566592
revocation-check none
rsakeypair TP-self-signed-1189566592
crypto pki certificate chain TP-self-signed-1189566592
certificate self-signed 01
[removed]
quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet3/0/1
interface FastEthernet3/0/2
interface FastEthernet3/0/3
interface FastEthernet3/0/4
interface FastEthernet3/0/5
interface FastEthernet3/0/6
interface FastEthernet3/0/7
interface FastEthernet3/0/8
interface FastEthernet3/0/9
interface FastEthernet3/0/10
interface FastEthernet3/0/11
interface FastEthernet3/0/12
interface FastEthernet3/0/13
interface FastEthernet3/0/14
interface FastEthernet3/0/15
interface FastEthernet3/0/16
interface FastEthernet3/0/17
interface FastEthernet3/0/18
interface FastEthernet3/0/19
interface FastEthernet3/0/20
interface FastEthernet3/0/21
interface FastEthernet3/0/22
interface FastEthernet3/0/23
interface FastEthernet3/0/24
interface GigabitEthernet3/0/1
interface GigabitEthernet3/0/2
interface FastEthernet4/0/1
interface FastEthernet4/0/2
interface FastEthernet4/0/3
interface FastEthernet4/0/4
interface FastEthernet4/0/5
interface FastEthernet4/0/6
interface FastEthernet4/0/7
interface FastEthernet4/0/8
interface FastEthernet4/0/9
interface FastEthernet4/0/10
interface FastEthernet4/0/11
interface FastEthernet4/0/12
interface FastEthernet4/0/13
interface FastEthernet4/0/14
interface FastEthernet4/0/15
interface FastEthernet4/0/16
interface FastEthernet4/0/17
interface FastEthernet4/0/18
interface FastEthernet4/0/19
interface FastEthernet4/0/20
interface FastEthernet4/0/21
interface FastEthernet4/0/22
interface FastEthernet4/0/23
interface FastEthernet4/0/24
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
interface Vlan1
no ip address
ip default-gateway 10.25.62.254
ip classless
ip http server
ip http secure-server
control-plane
line con 0
exec-timeout 30 0
password 7 045907130A27435C0D48
logging synchronous
login
line vty 0 4
exec-timeout 30 0
logging synchronous
login
line vty 5 15
login
end
10-29-2017 01:14 PM
This is from the show switch command:
office#show switch
Switch/Stack Mac Address : 0016.46e7.5880
H/W Current
Switch# Role Mac Address Priority Version State
3 Member 0000.0000.0000 0 0 Provisioned
*4 Master 0016.46e7.5880 9 0 Ready
