Need to widen the device default in PT 7.3
randyg1
Hi - Packet Tracer 7.0 would allow you to change the Router, Switch or whatever device's default from the smaller width window default to a wider window default. This was done by going to the File menu bar select Options> Preferences and then Custom Interfaces and then changing None to net.netacad.clearTerminalClearAgent.terminal.html. When I try the same thing is 7.3 it will not widen the default window, causing me and my students to have to maximize or manually widen the device window every time we open a device. That may not seem like much of an inconvenience but when the students and I have to do that literally hundreds of times each semester, it is highly annoying. Does anyone out there have a work-around for this issue? Thanks for you help in advance!
Randy
Martin L
so it is a bug in PT 7.3, right? if so, please let PT people know. thx
Is there a PT group? Didn't see it as an option when I posted.
