NetFlow Configuration issue
amolyeole02
Community Member
  • How do I configure NetFlow on a Cisco Catalyst 3650 switch running IOS version 03.07.01E with an IP Base license?
  • How can I check if NetFlow is enabled on a Cisco Catalyst 3650 switch?
  • Does the IP Base license on the Cisco Catalyst 3650 switch support NetFlow?
@amolyeole02
About license
Trim Level
Ingress NetFlow Table
Egress NetFlow Table
LAN Base
Not supported
Not supported
IP Base
8 K
16 K
IP Services
8 K
16 K
You can find answer for all your question on the link below
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/flexible_netflow/configuration_guide/b_fnf_3se_3650_cg/b_fnf_3se_3650_cg_chapter_010.html#d3644e135a1635
