Cisco Cat 9300 does not permit to modify mtu value on vlan interface
Hi everybody, i am facing an issue, in the company we have Catalyst switches 9200 and 9300, we have to put specific mtu value on physical and vlan interfaces, but only the Catalyst 9200 permit to do it, is there a additional configuration to do it on the Catalyst 9300?
Catalyst 9200
Model: C9200-24T
Firmware version: 17.06.03 CAT9K_LITE_IOSXE
Catalyst 9300
Model: C9300-24T
Firmware version: 17.06.04 CAT9K_IOSXE
7 Replies 7
@SYM Networking Engineer
 Why Cisco do not allow per vlan mtu change on 9300 I failed to find a doc. It seems you can set MTU with "system mtu" command or per interfaces.
Did you try
int vlan 434
 ip mtu  xxx
Device# configure terminal
Device(config)# interface gigabitethernet 0/1
Device(config-if)# ip mtu 900
Device(config)# system mtu 1600
Device(config)# exit
 I have found this doc where we can see this table. It seems you can setup MTU for L3 SVI but L3 SVI, as you are trying, is not listed here.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/217233-troubleshoot-mtu-on-catalyst-9000-series.html
Background Information
MTU Summary Table
Total Fram Size = MTU + L2 Header
Port Type
Default MTU - Bytes
Configured MTU - Bytes
L2 Header
Total Frame Size
L2 Access
1500
18
1518
9216
18
9234
L2 Trunk
1500
22
1522
9216
22
9238
L3 Physical Port
1500
18
1518
9216
18
9234
L3 SVI
1500
18
1518
9216
18
9234
IP MTU on L3 port
1500
Range is supported.
18
Based on the ip mtu configured value.
You can not,
it default 1500.
MHM
DanielP211
Hello!
The correct command is
int vlan XXX
ip mtu 9100
BR
****Kindly rate all useful posts*****
balaji.bandi
First, what is the use case for SVI to require MTU changes?
BB
M02@rt37
Hello @SYM Networking Engineer
The ip mtu command is available under interface configuration mode on the C9300, you can use it to set the MTU for IP packets on specific interfaces, including VLAN interfaces.
On the other hand, the command system mtu jumbo <value> is used to configure the global Layer 2 MTU (jumbo MTU) on a switch, specifically for interfaces handling jumbo frames. This setting defines the maximum size of Ethernet frames  that can be transmitted on the switch's interfaces. !!! Need a reload !!!
For routed interfaces, you may need to configure ip mtu separately if IP traffic needs a specific MTU.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-6/configuration_guide/int_hw/b_176_int_and_hw_9300_cg/configuring_system_mtu.html
The difference in MTU configuration between the C9200 and 9300 switches stems from their architectural design and intended use cases. C9200 supports the mtu command on individual L2 interfaces, providing more flexibility for per-interface MTU settings, which aligns with its role as a cost-effective, access-layer switch. In contrast, the C9300 is designed for more advanced features, such as SD-Access and large-scale deployments, and uses a global MTU management approach. On the 9300, the system mtu and system mtu jumbo commands configure L2 MTU globally, ensuring consistency across interfaces and simplifying management for features like VXLAN or MPLS. This difference reflects Cisco's design philosophy, where simpler devices like the 9200 allow for granular configuration, while higher-end switches like the 9300 prioritize scalability and uniformity. If granular MTU settings are required on the 9300, global MTU configurations should be adjusted, as the mtu command is not supported per interface.
Best regards
shambhu.kumar
Even if you configure ip MTU under VLAN interface in 9300 , it will not go beyond 1500. What is exact requirement,where it needed to configure MTU under VLAN level?
9300 have
In 9200 you have both options,
