Netflow Configurations
julito4589
Level 2
Level 2
I'm trying to configure Netflow on a Cisco 3925 runing IOS  Version 15.0(1r)M8.
These are the Netflow commands I'm using
flow record NFRECORD
match ipv4 source address
match ipv4 destination address
match ipv4 protocol
match transport source-port
match transport destintation-port
match ipv4 tos
match interface input
collect interface output
collect counter bytes
collect counter packets
flow exporter NFEXPORT
destination x.x.x.x
transport udp 9991
export-protocol netflow-v9
source gigabitEthernet 0/0
flow monitor NFMONITOR
record NTARecord
exporter NTAExport
cache timeout active 60
cache timeout inactive 15
int gig 0/0
ip flow monitor NFMONITOR input
And here's how I'm associating them with each interface
int g0/0
 ip flow egress
int g0/1
ip flow ingress
int g0/2
ip flow ingress
Interface g0/0 is on the LAN. The other two are WAN interfaces.
When I check the cache, I get a message that there are no cache entries. What am I missing?
Tower_3925_1#sh flow monitor NFMONITOR cache
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                               0
  High Watermark:                                0
  Flows added:                                   0
  Flows aged:                                    0
    - Active timeout      (    60 secs)          0
    - Inactive timeout    (    15 secs)          0
    - Event aged                                 0
    - Watermark aged                             0
    - Emergency aged                             0
There are no cache entries to display.
Richard Burts
Perhaps I am confused and missed something in your post. But it seems inconsistent to configure this
record NTARecord
exporter NTAExport
when your configuration calls the record NFRECORD and calls the exporter NFEXPORT
Rick
Rick
Sorry for the inconsistent info. I probably attempted to change the names in the post. Here's the output from the device
Tower_3925_1#sh flow exporter
Flow Exporter NTAEXPORT:
  Description:              User defined
  Export protocol:          NetFlow Version 9
  Transport Configuration:
    Destination IP address: x.x.x.x
    Source IP address:      y.y.y.y
    Source Interface:       GigabitEthernet0/0
    Transport Protocol:     UDP
    Destination Port:       9991
    Source Port:            59315
    DSCP:                   0x0
    TTL:                    255
    Output Features:        Not Used
Flow Monitor NTAMONITOR:
  Flow Record:       NTARECORD
  Flow Exporter:     NTAEXPORT
  Cache:
    Type:              normal
    Status:            allocated
    Size:              4096 entries / 262160 bytes
    Inactive Timeout:  15 secs
    Active Timeout:    60 secs
    Update Timeout:    1800 secs
Tower_3925_1#sh flow reco
Tower_3925_1#sh flow record
flow record NTARECORD:
  No. of users:       1
  Total field space:  30 bytes
  Fields:
    match ipv4 tos
    match ipv4 protocol
    match transport destination-port
Tower_3925_1#sh flow int
Tower_3925_1#sh flow interface
Interface GigabitEthernet0/0
  FNF:  monitor:          NTAMONITOR
        direction:        Input
        traffic(ip):      on
Interface GigabitEthernet0/1
        direction:        Input
        traffic(ip):      on
Interface GigabitEthernet0/2
        direction:        Input
        traffic(ip):      on
And here is the input from the monitor
Tower_3925_1#sh flow monitor NTAMONITOR cache
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                               0
  High Watermark:                                0
  Flows added:                                   0
  Flows aged:                                    0
    - Event aged                                 0
    - Watermark aged                             0
    - Emergency aged                             0
(Edit: added output of monitor)
julito4589
Level 2
Level 2
Does anyone have any input on this? Is the IOS I'm running an issue?
I tried a simpler config below, and my cache still shows empty
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export version 5
ip flow-export destination x.x.x.x 9991
ip flow-top-talkers
 top 20
 sort-by bytes
 cache-timeout 1
