09-15-2010 09:05 AM - edited 03-06-2019 12:59 PM
I observe a strange behaviour with Netflow on Catalyst 6500 with SUP720-3B running version 12.2(33)SXH2a :
Setup :
Traffic flow :
With this setup, all traffic flow through the VRF-A and VRF-B only receives the broadcasts on the VLAN 310. This can be demonstrated with the packet counters on the VLAN interface 310 on VRF-B.
Netflow entries on VRF-A :
As expected, all Layer-3 flows are present in the VRF-A netflow table but some L2 flows are also in the table, despite the fact that L2 flows creation
has been disabled...
Some of them is for instance :
110.56.6.222 10.56.57.81 udp :61983 :dns Vl310 :0x01 64 4 17:52:54 L3 - Dynamic
10.240.131.107 10.56.6.223 udp :137 :137 Vl200 :0x03 270 4 17:52:54 L2 - Dynamic
10.56.57.81 10.56.6.222 udp :dns :61983 Vl200 :0x00 0 4 17:52:54 L2 - Dynamic
10.56.55.248 10.56.6.222 udp :dns :33468 Vl200 :0x036 5868 36 17:52:57 L3 - Dynamic
10.56.6.130 10.56.52.188 tcp :1272 :445 Vl200 :0x00 0 20 17:52:38 L2 - Dynamic
10.56.6.222 10.241.154.31 udp :58326 :dns Vl200 :000 0 36 17:52:29 L2 - Dynamic
10.56.6.222 10.240.5.122 udp :54355 :dns Vl310 :0x01 61 28 17:52:30 L3 - Dynamic
10.56.57.218 10.56.6.131 udp :53213 :53213 Vl200 :0x00 0 16 17:52:42 L2 - Dynamic
10.240.4.93 10.240.85.119 tcp :3978 :445 Vl200 :0x060 11112 36 17:52:58 L3 - Dynamic
10.240.49.45 10.56.33.94 tcp :8080 :4072 Vl310 :0x01 52 20 17:52:38 L3 - Dynamic
Netflow entries on VRF-B :
In VRF-B, there is no L3 flows because no routed traffic pass through this routing instance, as expected. But the strange thing is that we still see several thousands of L2 flow (same indbond and outboud interface : VLAN 310)
here is an extract of the table in VRF-B containing only L2 flows :
10.56.33.92 10.56.6.222 udp :dns :62830 Vl310 :0x01 208 9 17:56:06 L2 - Dynamic
10.56.33.92 10.56.6.222 udp :dns :58655 Vl310 :0x01 137 25 17:55:50 L2 - Dynamic
10.56.34.156 10.56.6.222 udp :dns :51187 Vl310 :0x01 55 12 17:56:03 L2 - Dynamic
10.240.42.211 10.56.33.94 tcp :8080 :3844 Vl310 :0x02 104 12 17:56:03 L2 - Dynamic
10.56.7.139 10.240.23.196 tcp :1360 :1494 Vl310 :0x02370 114889 183 17:56:08 L2 - Dynamic
10.240.42.121 10.56.6.176 tcp :5061 :2055 Vl310 :0x01 46 10 17:56:05 L2 - Dynamic
10.56.6.222 10.56.33.92 udp :54334 :dns Vl310 :0x01 65 2 17:56:13 L2 - Dynamic
10.56.7.69 10.240.142.118 tcp :10000 :2675 Vl310 :0x07 322 34 17:56:11 L2 - Dynamic
10.56.6.222 10.56.33.92 udp :63074 :dns Vl310 :0x01 63 10 17:56:05 L2 - Dynamic
10.240.142.20 10.56.7.69 tcp :www :1124 Vl310 :0x04 1964 10 17:56:10 L2 - Dynamic
My Questions :
Thank you for any hints
Yves Haemmerli
