Netflow Interface L3 Capture
Rafael Mendes
Level 2
Level 2
Hello Everyone,
I trying to configure netflow feature in my cisco 4507, using ntop for capture the packets.
But, the switch sends all traffic passed, i need so four ports to capture, and not all traffic.
Its possible configuring so four ports to send the netflow traffic? the ports are L3 mode.
4507 Conf :
ip route-cache flow
ip flow ingress
ip flow-export version 5
ip flow-export destination x.x.x.x  9996
Tks a lot.
Rafael Mendes
Giuseppe Larosa
Hello Rafael,
you should have provided additional information:
a show module to see what type of supervisor you have
a show ver | inc image
to see what IOS image is running
However, the answer is negative:
>> Enabling NetFlow on a per interface basis is not supported on a Catalyst 4500 switch.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/52sg/configuration/guide/nfswitch.html#wp1022037
even in 12.2(54)SG
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/nfswitch.html#wp1014923
to be noted I see a new IOS XE 3.1.0 SG for C4500 but this is really new
you need to implement a filter on the netflow collector using the SNMP ifindex of the desired interfaces
you should be able to see SNMP ifindex by using
show snmp mib ifmib ifindex
Hope to help
Giuseppe
