08-13-2014 11:42 AM - edited 03-07-2019 08:23 PM
Hello, I have 3750x running c3750e-universalk9-mz.122-55.SE5 layer 3 capable. Im trying to enable net flow on the switch but for some reason the flow commands dont appear to be available in config t mode. Are there some other global commands that have to be enabled first in order for the netflow commands to be available or is it the image that doesnt support netflow?
Andy
Solved! Go to Solution.
08-13-2014 03:24 PM
Hey Andy,
The license on the box is ipbase:
StoreIndex: 1 Feature: ipbase Version: 1.0
License Type: Permanent
License State: Active, In Use <<<<<< look here
License Priority: Medium
License Count: Non-Counted
So it should support netflow, however only other thing required is the network servie module, so have a look on this link for more information:
HTH.
RS.
08-13-2014 01:51 PM
Hey Andy,
Regarding your question,
Flexible NetFlow is supported only on the Catalyst 3750-X and 3560-X switch running the IP base or IP services feature set and equipped with the network services module. It is not supported on switches running the NPE or the LAN base image.
So check the running feature set with command "show license all" and change if required.
HTH.
Regards.
RS.
08-13-2014 02:58 PM
Thanks Rajeevsh,
I ran the command I got the output below, i do see ipbase in there but dont know if that means its active..
Maybe it needs to have IP services as you pointed out..
Thanks for looking at this..
andy
inmu-tcs-inet1-sw#sh license all
License Store: Primary License Storage
StoreIndex: 0 Feature: lanbase Version: 1.0
License State: Active, Not in Use
License Store: Evaluation License Storage
StoreIndex: 0 Feature: ipservices Version: 1.0
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
License Priority: None
I also ran it on another 3750x where netflow commands seem to work and the output is different..see below:
dmz-srvdist1a-sw#sh license all
StoreIndex: 0 Feature: ipbase Version: 1.0
08-13-2014 03:24 PM
Hey Andy,
HTH.
RS.
08-13-2014 03:38 PM
Perfect Thanks for your help..
Andy
08-13-2014 03:56 PM
Always happy to help :)
08-13-2014 03:27 PM
Also i checked that minimum IOS requirement for this service module to work is 15.(0)1SE and you are running 12.2(55)SE5 so I believe you need a hardware upgrade as well.
RS.
