Netflow Nexus 7000
Joris Deprouw
Hi all,
A few months ago I have configured netflow on a Nexus 7000 with NX-OS version 6.0.2.
This was my config:
flow exporter Fluke_NetflowTracker
  description export netflow to Fluke_NetflowTracker
  destination x.x.x.x use-vrf management
  transport udp 2055
  source mgmt0
  version 9
flow exporter Fluke_Optiview
  description export netflow to Fluke_Optiview
  destination x.x.x.x  transport udp 2055
  source Vlanx
  version 9
flow monitor MonitorTrafficToFluke
  record netflow-original
This flow was activated on some SVI's. "ip flow monitor MonitorTrafficToFluke input"
Recently we have upgraded the NX-OS to version 6.1.3. The netflow keeps on working, but the syntax of the netflow configuration has changed. Now you have to add a sampler as well.
So I have created the following sampler.
sampler NetFlow-Sampler
  description Netflow Sampler
  mode 1 out-of 1000
When I want to update the current configuration with the sampler I can't adapt or remove the existing netflow configuration on the SVI.
NK7(config-if)# no ip flow monitor MonitorTrafficToFluke input
ERROR: A sampler must be configured for an interface on an F2 card
NK7(config-if)# ip flow monitor MonitorTrafficToFluke input sampler NetFlow-Sampler
An additional 1:100 sampler, over the configured sampler is applicable for F2 ports
Error: Sampler can not be changed on Interface Vlanx. Remove flow monitor first.
ERROR: Command has failed
How do I update or remove the existing configuration on the SVI.
I want the config to be "ip flow monitor MonitorTrafficToFluke input sampler NetFlow-Sampler"
Thank you,
Best Regards,
Joris
Richard Michael
Hi Joris,
Try no feature netflow under the interface and try to re-apply the whole configs. Since its a F2 we dont support config changes until 6.2(2) only way is to remove the configs using no feature netflow and re-applying it.
Richard.
*Rate if its useful
Richard Michael
Hi Joris,
Richard.
*Rate if its useful
Hi Richard,
Disabling the netflow feature does the trick.After re-enabling it I can use the new syntax.
Thanks for you feedback.
Best Regards,
Joris
Please help i try to no feature netflow under interface and re-enable but still the same error.
CSW(config-if)# ip flow monitor NETFlow-Monitor input
ERROR: A sampler must be configured for an interface on an F2 card or F2e/F3 mixed vdc
CSW(config-if)# ip flow monitor NETFlow-Monitor input sampler NetFlow-Sampler
ERROR: The sampler NetFlow-Sampler does not exist.
