Netflow on 2960x - How to configure netflow, is it possible?
mrochac
Good afternoon (from where i am) to everyone - i have PRTG working fine with netflow collecting traffic for my routers but i cant seem to be able to get the same results from 2960x switch.
what am i missing?
Your help is greatly appreciated.
Reza Sharifi
Overall, the 2960x is layer-2 and has limited NetfLow functionalities and also depend on the license you have,
here is the config guide:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/fnf/configuration_guide/b_nf_152ex_2960-x_cg.pdf'
5 Replies 5
Reza Sharifi
Hi Reza - how do i find out licensing?
"sh license" or even better "show version" should show you what type of license you have installed.
Index 1 Feature: lanlite
Period left: 0 minute 0 second
Index 2 Feature: lanbase
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
License Count: Non-Counted
"show version" is probably a better choice.
