Netflow on a Cisco 2821
Thomas Summers
I have  customer that we have configured netflow on the 2821 router that their traffic is on.  Currently the company they have contracted with for the analysis is seeing data duplication.  Below is the configuration for the interface and the router
Cisco 2821;
interface GigabitEthernet0/0
description TVC-FI-Ethernet-Fiber-Ethernet link
ip address 216.255.164.33 255.255.255.248 secondary
ip address 192.168.5.1 255.255.255.0 secondary
ip address 216.255.166.129 255.255.255.128 secondary
ip address 192.168.4.1 255.255.255.0 secondary
ip address 192.168.166.1 255.255.255.0 secondary
ip address 192.168.167.1 255.255.255.0 secondary
ip address 216.255.164.49 255.255.255.240 secondary
ip address 216.255.166.65 255.255.255.192 secondary
ip address 216.255.166.49 255.255.255.240 secondary
ip address 216.255.164.129 255.255.255.128 secondary
ip address 216.255.164.65 255.255.255.192 secondary
ip address 67.231.74.1 255.255.255.192 secondary
ip address 67.231.76.1 255.255.255.128 secondary
ip address 67.231.77.1 255.255.255.0 secondary
ip address 216.255.164.1 255.255.255.224
no ip redirects
ip flow ingress
ip flow egress
load-interval 30
duplex auto
speed 100
ip flow-cache timeout inactive 10
ip flow-cache timeout active 1
Richard Burts
Thomas
You have shown us one interface that enables NetFlow both in and out. But you have not told us whether there is any other interface on the router that also has NetFlow enabled. This could be a source of duplication and we need to know this.
Rick
Rick
jakewilson
Hi Thomas,
Make sure the export includes the "flow direction" element which indicates if the flow was metered ingress or egress.  Without flow direction, you will see the exact same flow twice.
There is a decent blog on our web site that helps explain ingress vs egress.
I hope this helps.
Jake
