Netflow sampling limitation on Nexus 7ks
Mark Malone
We are seeing a limitation with netflow on 7ks risky to do 1:1 flows and TAC  Cisco sees enabling 1 out of 1 sampling rate as a risk and they say it is not recommended (CPU spike etc) on 7ks and its not recommended , we have been testing it on several L3 interfaces and its working ok so far but were a bit unsure whether to try all interfaces as per Cisco's advice its not supported , has anybody tried to do all there l3 interfaces was any strange behaviour seen ?
Is there any other recommendation anyone else got or has ?
Problem Description
The netflow is enabled on N7K, but the reported traffic rate by netflow is different from the real traffic rate on interfaces.
Action Taken
  1. Checked the netflow configuration and hardware installed.
  2. Shared the netflow configuration guide and explained that M3 only supports sampled netflow.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/system-management/guide/b_Cisco_Nexus_7000_Series_NX-OS_System_Management_Configuration_Guide/b_Cisco_Nexus_7000_Series_NX-OS_System_Management_Configuration_Guide_chapter_011000....
Resolution
As we discussed, The M3 supports only sampled netflow due to hardware limitation, so, the tranditional/1:1 netflow isn’t supported.
F2, F2e, F3, and M3 Series modules support only sampled NetFlow.
Thanks Mark
0 Replies 0
