Netflow sampling ?
tedauction
Hello, I am setting up Netflow v9 on a big group of switches and routers.
These devices are under heavy load. Should I be using sampling or is just not necessary unless the devices are handling heavy traffic ?
Or is it best practice to always do sampling of some form ?
My concern is that I am degrading the quality of flow information by using my current sampling rate of 32:1.
Thanks for any advice.
Mark Malone
It all depends if that's good enough for you , sampling is only to reduce cpu on lower end devices that struggle with large flows , we collect everything on our ASRs,4331s etc even with large load and we don't get any cpu effect , it may also be the case that your collector can only handle a certain amount of incoming flows and reducing it to sampling rate may not overload it but if your devices and collector can handle it I wouldn't use sampler at all again though it can depend why your collecting flows in the first place , you may only need samples of whats going on in flows, for security and network investigations we collect everything
why not test a device with full load see what happens does cpu increase sending full flow , does the collector struggle and then make a decision if you need to take samples instead with flows
another aspect might be the WAN load increase:
In theory the NetFlow traffic sent over a WAN line would increase the load by 1-3%.
But it might be higher (I remember over 10% in one case of DNS server misconfigured).
And it could be more if sending NetFlow statistics from your LAN over a WAN to your collector.
Or several hundreds/thousands sites sending NetFlow data to a single collector - that could increase the collector WAN line traffic considerably.
But generally, if your network and CPUs can handle it, full (not sampled) NetFlow should be a preferred solution.
Best regards,
Milan
Have you considered using Flexible NetFlow to reduce the details that you export? For example, by not exporting source and destination port, you can reduce flow volumes by over 80% and still have 100% of the data needed for accounting.
https://www.plixer.com/blog/sflow/how-to-avoid-ipfix-or-netflow-sampling-vs-sflow/
As Mark Malone pointed out, it depends on what you want to do with the collected flows.  For accounting, the above works well.  For threat detection, not so good.
