NetFlow
glaucio
Frequent Visitor
Frequent Visitor
I am looking for solution to analyze, monitor, troubleshooting and find out issues at data traffic flow like loss connection, packet retransmission on Cisco Switch 6500 at LAN. I have already seen suggestion to enable Netflow feature with a NetFlow Collector using software from many companies (e.g FlukeNetworks, ManageEngine, Plixer International and SolarisWinds) but it only looks like useful for WAN environment.
Can I use Netflow feature for LAN environment?
Can anyone give a suggestion?
Thanks in advance.
Glaucio
gauravshar
Level 5
Level 5
Hi Glaucio,
I would like to know what all config changes you did to enable netFlow in your 6500 switch. As far as I know it should work for WAN as well LAN environment.
--gaurav
Not all switch platforms support netflow
For eg
6500 supports netflow
http://www.cisco.com/warp/public/473/netflow-catalyst6500.pdf
4500 with SupIV and SupV also support neflow but you need to install the daughter card (WS-F4531 )
On the old 5500 RSM based switches, you require the NFFC card for netflow
Narayan
Hi Gaurav,
I have not deployed this solution yet but you can easily find this configuration (CATOS/CATIOS platform) on Cisco WebSite. I have decided to deploy NetFlow and SNMP RMON MIB for monitoring all IP-based traffic on Switch interfaces at LAN and WAN environment.
Glaucio
Joseph W. Doherty
From the level of detail you're looking for, i.e. loss connection and packet retransmission, I'm uncertain Netflow data alone will suffice. If you have a 6500, something such as the Network Analysis Module might be required. See http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps5025/product_data_sheet0900aecd804bab11_ps708_Products_Data_Sheet.html
