Netmiko on many devices
Moudar
What i need is how to apply this code on many devices?
I tried to make a text file with many IP addresses in it, but the code was applied only on the last IP i had on my txt list!
from netmiko import ConnectHandler
from getpass import getpass
password = getpass()
net_connect = ConnectHandler(host="172.22.1.97", username="cisco", password=password, device_type="cisco_ios", secret='cisco')
show_vlan_command = net_connect.send_command('show vlan b', use_textfsm=True)
net_connect.enable() #enable mode
which_vlan = input("wich VLAN do you want to check?: ")
#print(which_vlan)
for i in show_vlan_command:
if i['vlan_id'] == which_vlan:
print(quit('VLAN is already there')) #to break out the code if a vlan already there!
for x in show_vlan_command:
if x['vlan_id'] != which_vlan:
print(f'VLAN is not there, create VLAN')
break
vlan_name = input("vlan name?: ")
create_new_vlan = [
(f'vlan {which_vlan}'),
(f'name {vlan_name}'),
create_vlan = net_connect.send_config_set(create_new_vlan)
#print(create_vlan)
show_vlan_command = net_connect.send_command(f'show vlan b | include {vilket_vlan}', use_textfsm=True)
print(show_vlan_command)
6 Replies 6
Jon Marshall
I can't see any code here that would read in the text file and loop through the IPs ?
Also when you post your code there is an option to insert as code which makes it much more readable.
Jon
Moudar
#print(which_vlan)
break
create_new_vlan = [
#print(create_vlan)
carstenlymann1
Hi @Moudar
I agree with @Jon Marshall  there is no point in your code where you loop through a list of ip adresse.
Here is what i have done in my code :
import json
import os
working_dir = os.getcwd()
try:
    with open(working_dir + '/device_list.txt', 'r') as json_file:
        list_of_ip = json.load(json_file)
        for l in list_of_ip:
            print(l)
except:
    print('No ip list found')
for ip in list_of_ip:
    device = {
        'device_type': 'cisco_ios',
        'ip': ip,
        'username': username,
        'password': password
 I use a try where i print the ip out, so i can see that ip while script is running.
And then the for loop, to loop through the list_of_ip, to use the ip variable to put into the device variable.
And then everything you wants to do, you put that under the for loop as well. (what i usely still do is start out with only having some basic show commands in my script. That way if i have made an error, i want harm my device if its done in production devices.)
["192.168.1.10", "192.168.1.20", "192.168.1.30", "192.168.1.40", "192.168.1.50", "192.168.1.60"]
And this could be how the device_list.txt is made.
Feel free to ask if you got any questions.
Please remember to select a correct answer and rate helpful posts
/ Carsten
My devices.txt file looks like this:
172.22.2.1
172.22.2.2
172.22.2.3
is this right?
how should a json file with ip addresses look like?
This is how my txt file is..
/ Carsten
I agree with @carstenlymann1 and @Jon Marshall , there is no reference to any txt file in your code. Also, in your code, since you apparently have configured 'enable secret' passwords, you need to reference that password:
net_connect = ConnectHandler(host="172.22.1.97", username="cisco", password=password, secret=xxx, device_type="cisco_ios", secret='cisco')
The link below has I think a pretty good sample config:
https://underdogit.net/2021/08/10/use-netmiko-to-connect-to-multiple-devices-with-a-text-file-100daysofcode/
