Network Analyzer
Mhon Baul
Can someone tell me a best tool to analyze network? I'm having problem in a certain time. Please help ASAP.
Many Thanks,
reymon
Leo Laohoo
Wireshark (free)
Wildpacket's OmniFlow
Raymon,
I'd recommend you to use Wireshark for Network protocol analyzer.
Here you go : http://www.wireshark.org/
HTH,
Toshi
Thanks thotsaphon. Im using right now the wireshark but im not good to look at it on how to look w/c one is causing the problem. Do you know which tool i can use to identify the traffic that captured by wireshark?
Many Thanks,
Remon
