Network Audit
I am planning for Network audit
Device: 7200 Router, 3845 router
Switch: 2960,3750,4500,4900M
ASA
I am mainly doing the audit on this perspective:
Vulnerablities
Perfomance
Bittleneck
Pls share some docuemnt/ppt/guidelines
Br/Subhojit
there are many tools which you can use for doing the above task.
There is no generalized format or documents which you can find
if you want to do Vulernability Assessment:- Use Nipper Studio
If you want to do the Performance:- Use Manage Engine or Solar winds which usually works on SNMP based data collection.
Manageengine comes with IP SLA feature which test the SLA for the link and performance which can help you finding the Bottle neck.
Please rate if helpful
Nitesh
