Network Configuration Problem
krishna das
Hi team
Iam new one in this side. I have 3750G series 24-ports cisco switch, microsoft 2008 server. i need to know about how to configure on cisco switch with multiple vlans. DHCp are comming from Microsoft server with multiple DHCP scope for each vlan. So how i configure multiple vlans on specified switch here.
iam giving vlans
vlan 10 management
vlan 20 voip
vlan 30 users
ipaddress range 192.168.10.0/24 for vlan 10
ipaddress range 192.168.20.0/24 for vlan 20
ipaddress range 192.168.30.0/24 for vlan 30
i also needto know about how communication possible from switch to Microsoft Server 2008 and its switch configuration.Rough figure of my pan are given here.please go through on it.
Please help me.
2 Accepted Solutions
This is a basic configuration. Fell free to ask more questions.
3750
vlan 10
name  managment
vlan 20
name voip
vlan 30
name users
vlan 40
name servers
interface vlan 10
ip address 192.168.10.1 255.255.255.0
ip helper-address [dhcp IP address]
interface vlan 20
 ip address 192.168.20.1 255.255.255.0
interface vlan 30
 ip address 192.168.30.1 255.255.255.0
int vlan 40
 ip address 192.168.40.1 255.255.255.0  // you can change it depending on the ip of DHCP server
int fast0/5
des DHCP server
switch port access vlan 40
ip routing
ip route 0.0.0.0 0.0.0.0 [ip address of firewall]
int fast 0/22
no switchport
ip address [ IP in the same range of your modem]  or ip address dhcp
int fa0/23
des Connect to switch
switchport mode trunk
switchport trunk allowed vlan 10 30
int fa0/24
int range f0/1-12
des Connect to voip
switchport access vlan 20
Switch1
vlan 10
name  managment
vlan 30
name users
int vlan 10
ip address 192.168.10.2 255.255.255.0
ip default-gateway 192.168.10.1
int fa0/24
des Connect to 3750
int fa0/0
des Connect to client
switchport access vlan 30
int fa0/1
Switch2
vlan 10
name  managment
vlan 30
name users
int vlan 10
ip address 192.168.10.3 255.255.255.0
int fa0/24
des Connect to 3750
int fa0/1
int fa0/2
You need to set ip and default gateway for all clients and VOIP devices and servers
Hope it helps,
Masoud
Adding  to my previous comment
For SSH connectivity.
IP domain-name Cisco.com
IP ssh version 2
username cisco passwork cisco
Crypto key generaye RSA  [ press enter for questions]
line VTY 0 4
login local
transport input SSH [telnet if needed]
Masoud
25 Replies 25
3750
vlan 10
name  managment
vlan 20
name voip
vlan 30
name users
vlan 40
name servers
interface vlan 10
interface vlan 20
interface vlan 30
int vlan 40
int fast0/5
des DHCP server
ip routing
int fast 0/22
no switchport
int fa0/23
int fa0/24
int range f0/1-12
des Connect to voip
Switch1
vlan 10
name  managment
vlan 30
name users
int vlan 10
int fa0/24
des Connect to 3750
int fa0/0
int fa0/1
Switch2
vlan 10
name  managment
vlan 30
name users
int vlan 10
int fa0/24
des Connect to 3750
int fa0/1
int fa0/2
Hope it helps,
Masoud
Thank You so much Masoud.
But one doubt all dhcp configured for vlans from windows 2008 server will automatically come inside cisco switch 3750G, when i create as  you mentioned on inter fas 0/5. If it is needed to change no switch port with ip address.
Yes, you can. Both ways work.
int fa0/5
 no switchport
ip address [used for gateway of DHCP server]
You do not need VLAN 40 anymore .
 Thanks for rating.
Masoud
Thank you.
If you don't mind what about outgoing connection routing to internet from those vlans end devices.where i configured that?.And i need some restriction for these vlan communication. For example Vlan 10 has all access in vlan 20 and 30, but vlan 20 and 30 has no access on management network(vlan 10).what we do for that purpose.
You are welcome.
ip routing
int fast 0/22
descreption connect to firewall
no switchport
ip address [ IP in the same range of your firewall]  or ip address dhcp
If your endpoint devices have gateway, with the commands above they will route to the modem. Make sure your modem works for all subnets(Policy and NAT are configured correctly).
I am working on your second question. I will get back to you in a moment
Masoud
  Thnaks Masoud and Paul.
  After i check. i will update. Again thanks for your valubale time.
You are welcome. Glad to help. Just do not forget to set "ip routing" command on 3750 and also check connectivity segment by segment. For example, ping 192.168.10.1(SVI) from 192.168.10.2 and ping 192.168.20.1(SVI) from 192.168.20.2 and repeat it for others subnets too.
Be waiting for you feedback.
Masoud
Thank you.
Sure, after complete i will update.
Thanks for advance.
I have doubt.
my Firewall ip 10.20.30.1
My dhcpserver IP 10.20.30.5. Under these dhcp server i created below dhcp pool.its on 2012 windows server.
My other dhcp pools are 10.20.40.10 10.20.40.100
My other dhcp pools are 10.20.50.10 10.20.50.100
Please which ip should i configured on the switch for geting above all dhcp pool on the switch.is it any ip range of dhcpserver?
Your dhcp server is behind the firewall?
On switch,under all interface VLANs, you need to configure,
Ip helper-address 10.20.30.5
Make sure you permit access to 10.20.30 5 on firewall if dhcp is behind the firewall.
Let me know if I understood your question correctly. Your last configuration and sketch of your topology would be helpful,
Masoud
Thanks Masoud.
Yes DHCP server behind firewall.
Sure.
Thanks lot.
Hello Team.
Please help.
I am not getting DHCP IP from windos2012 to 3750G switch.I created dhcp relay agent on windows 2012.DHCPserver ip 10.20.30.9 and port which I connect that server to switch 3/0/24,its ip is 10.20.30.199.
Then I created vlan
vlan 10
name  management
interface vlan 10
ip address 10.27.130.1 255.255.255.0
ip helper-address 10.20.30.9
interface range GigabitEthernet 3/0/1-12
switchport mode access
switchport access vlan 10
Then I connected 3/0/1 to a laptop and assign it dhcp. i cant get dhcp ip for that laptop
Ping from port 3/0/24 to dhcp server ip ok, because these are in same range.
Please help me. why I cant get dhcp for laptop which connected that switch. i also changed desktop also. If there is any misconfiguration.
Thanks for advance.
Does your dhcp server have default gateway?
Can you
ping 10.20.30.9 source 10.27.130.1
Windows firewall is off on dhcp server?
No, DHCP server have not default gateway. DHCP server directly connected to switch port 3/0/24.I didn't check that ping, tomorrow only I can check. Windows firewall is off in DHCP server. There is any other problem on my configuration.
Thanks for your replay
